Nitty Gritty Mini Pro Clean and Ready
MrBuhl
Mmm. My MiniPro 1 just returned from a full factory refresh and ready to scrub some vinyl goodness tonight! I'm feeling a Blue Fox Friday night coming!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
gots to get me a vinyl cleaning machine!
Thanks RNT - So excited! I bought this one dirt cheap, had a leaky pump - but the factory refresh/repair is very reasonable and seems thorough, and got me into this unit for 1/3 of new so I'm pretty happy so far! It did seem to take forever though - they've had it about 7-8 weeks I think.
Can't wait to see how it works tonight now that it's factory fresh.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Be careful about the type of fluids you use in the NG. DO NOT use any enzyme defeating fluids - they will eat right through your seals. I have used NGs Pure fluids and some homebrew fluids. I also suggest scrubbing your LPs first with a MoFi brush and fluid prior to putting it on the NG MiniPro.[
Hey @miner thanks - I have a couple bottles of the NG Pure cleaner - and they included two as well with the refurb which was nice of them.
I have a Spin Clean that I've been using previously, so they do/have gotten a bit of a prescrub already, but I'm hoping this will take the cleaning to the next level with the dual vac sweeps. Plus it will be so much faster!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
If it is as good as the VPI that cleaned 10 of my LPs you are going to LOVE
the results. You could end up with a collection with NO pops or clicks.
Well, maybe not but I was impressed!! -
That hardest thing I spent money on was my VPI record cleaner at around $650 it was hard to do, but now that I have had it awhile it was worth every penny.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I agree with this statement 100%.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I own a spin clean, a diskwasher kit , a zerostat, and a couple of antistat brushes. I need to invest in a Nitty Gritty or a VPI one of these days.Home Theater
I keep eyeing zerostats - do you think it makes a solid difference? I ran the NG last night on about six albums - WOW - what a difference, not just clean-er of pops and ticks, but I think the dynamic range increased as well - old albums less cloudy sounding.
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I sure getting the junk out of those grooves has to help the sound a lot.
I know dust settles none stop and sometimes after cleaning a record and then playing it, it seem by the end of 1 side of the record you can see some junk on the needle already and I wonder how much gets back into the grooves?
And I always use a distilled water rinse to finish the cleaning.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Ahhh - a rinse certainly makes sense Darryl - hadn't considered that. And good morning BTW!
That dang machine really is slick though I tell ya - both sides at once, and done in less than a minute. Dry and ready to play. I can finally get rid of my dish rack on the vinyl shelves LOL!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
yep glad you like the machine, they make it a lot easier.
I saw some stuff from MOFI called pure record rinse so I bought a bottle, basically they call it triple distilled water. so after It ran out I just filled the bottle with regular distilled water seems to work just fine.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Cool - I have an empty bottle of NGPure 2 - maybe I'll try loading that up with some distilled and see what's what!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Zerostats definitely help against static electricity, they are not made by discwasher anymore and are pricey but effective.Home Theater
Thanks!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
my 70's zerostat worked...
dunno about the new ones. -
I have been looking in to picking up a zero stat as I have horrible static issues. I am worried it will not work though and thats a lot of cash on a maybe.
few things that help with the static. The Zerostat & Hunt EDA Mk 6 Carbon Fiber Record Brush it like a 3 sided brush depending how you tilt it.
http://www.audioadvisor.com/prodinfo.asp?number=ZESTAT
http://www.musicdirect.com/p-7193-hunt-eda-mk-6-carbon-fiber-brush.aspx2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I have a Super Exstatic that I use while holding the metal back plate and touching the ground screw for a couple of spins in a hope to clear static and any dust on the record but still when I lift the lp off the turntable it actually tugs at the hair on my arm. I am hoping the Zerostat will be my magic solution because it is god awful annoying.
