Nitty Gritty Mini Pro Clean and Ready
MrBuhl
MrBuhl Posts: 2,419
edited April 2015 in 2 Channel Audio
Mmm. My MiniPro 1 just returned from a full factory refresh and ready to scrub some vinyl goodness tonight! I'm feeling a Blue Fox Friday night coming!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
  • [Deleted User]
    [Deleted User] Posts: 10,716
    gots to get me a vinyl cleaning machine!
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks RNT - So excited! I bought this one dirt cheap, had a leaky pump - but the factory refresh/repair is very reasonable and seems thorough, and got me into this unit for 1/3 of new so I'm pretty happy so far! It did seem to take forever though - they've had it about 7-8 weeks I think.
    Can't wait to see how it works tonight now that it's factory fresh.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • miner
    miner Posts: 1,305
    Be careful about the type of fluids you use in the NG. DO NOT use any enzyme defeating fluids - they will eat right through your seals. I have used NGs Pure fluids and some homebrew fluids. I also suggest scrubbing your LPs first with a MoFi brush and fluid prior to putting it on the NG MiniPro.
  • MrBuhl
    MrBuhl Posts: 2,419
    miner wrote: »
    Hey @miner thanks - I have a couple bottles of the NG Pure cleaner - and they included two as well with the refurb which was nice of them.
    I have a Spin Clean that I've been using previously, so they do/have gotten a bit of a prescrub already, but I'm hoping this will take the cleaning to the next level with the dual vac sweeps. Plus it will be so much faster!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • [Deleted User]
    If it is as good as the VPI that cleaned 10 of my LPs you are going to LOVE
    the results. You could end up with a collection with NO pops or clicks.
    Well, maybe not but I was impressed!!
  • voltz
    voltz Posts: 5,384
    That hardest thing I spent money on was my VPI record cleaner at around $650 it was hard to do, but now that I have had it awhile it was worth every penny.
  • hochpt21
    hochpt21 Posts: 5,423
    voltz wrote: »
    I agree with this statement 100%.
    gudnoyez Posts: 8,172
    I own a spin clean, a diskwasher kit , a zerostat, and a couple of antistat brushes. I need to invest in a Nitty Gritty or a VPI one of these days.
  • MrBuhl
    MrBuhl Posts: 2,419
    gudnoyez wrote: »
    I keep eyeing zerostats - do you think it makes a solid difference? I ran the NG last night on about six albums - WOW - what a difference, not just clean-er of pops and ticks, but I think the dynamic range increased as well - old albums less cloudy sounding.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    I sure getting the junk out of those grooves has to help the sound a lot.
    I know dust settles none stop and sometimes after cleaning a record and then playing it, it seem by the end of 1 side of the record you can see some junk on the needle already and I wonder how much gets back into the grooves?
    And I always use a distilled water rinse to finish the cleaning.
  • MrBuhl
    MrBuhl Posts: 2,419
    voltz wrote: »
    Ahhh - a rinse certainly makes sense Darryl - hadn't considered that. And good morning BTW!
    That dang machine really is slick though I tell ya - both sides at once, and done in less than a minute. Dry and ready to play. I can finally get rid of my dish rack on the vinyl shelves LOL!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    yep glad you like the machine, they make it a lot easier.
    I saw some stuff from MOFI called pure record rinse so I bought a bottle, basically they call it triple distilled water. so after It ran out I just filled the bottle with regular distilled water seems to work just fine.
  • MrBuhl
    MrBuhl Posts: 2,419
    Cool - I have an empty bottle of NGPure 2 - maybe I'll try loading that up with some distilled and see what's what!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    Zerostats definitely help against static electricity, they are not made by discwasher anymore and are pricey but effective.
  • MrBuhl
    MrBuhl Posts: 2,419
    gudnoyez wrote: »
    Thanks!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • [Deleted User]
    my 70's zerostat worked...
    dunno about the new ones.
  • Simplyrandom
    Simplyrandom Posts: 119
    I have been looking in to picking up a zero stat as I have horrible static issues. I am worried it will not work though and thats a lot of cash on a maybe.
  • voltz
    voltz Posts: 5,384
    edited May 2015
    few things that help with the static. The Zerostat & Hunt EDA Mk 6 Carbon Fiber Record Brush it like a 3 sided brush depending how you tilt it.
    http://www.audioadvisor.com/prodinfo.asp?number=ZESTAT
    http://www.musicdirect.com/p-7193-hunt-eda-mk-6-carbon-fiber-brush.aspx
  • Simplyrandom
    I have a Super Exstatic that I use while holding the metal back plate and touching the ground screw for a couple of spins in a hope to clear static and any dust on the record but still when I lift the lp off the turntable it actually tugs at the hair on my arm. I am hoping the Zerostat will be my magic solution because it is god awful annoying.
