Does anyone use a Tube amp with SDA's?
I am really kicking around buying a YAQIN MC-100B intergrated Stereo Tube amp.
Does anyone have thoughts good and bad on using that with my speakers?
I have heard Canadian HI-fi is a good dealer?
    F1nut Posts: 51,809
    I don't know about that integrated, but plenty of folks including myself have used tube amps with SDA's.
    edited May 2015
    I've heard good things about that amp as well. And I run a Chinese made tube amp on SDAs with good results (a Jolida along with their tube CD player-a few years and still ticking).
    The prices on those amps is REALLY falling! Tubes and SDAs is kinda a no brainer.
  • vcwatkins
    vcwatkins Posts: 1,993
    I'm currently trying out a Rogue Cronus Magnum (KT120) integrated with the 1.2's in the den and I'm liking it a lot. It's a different sound than I'm used to with the Sunfire - details pop out in unexpected places and bass is not as tight - but it's VERY involving. Not sure what I'll do at this point. Keep the Rogue here if I had to guess.
    Craig
  • PolkieMan
    PolkieMan Posts: 2,446
    Thanks for all the comments. :) I have always wanted one, and to not try it, well I am not going to be around forever and the concern was with the common ground and the limited power but the power is different with tubes somewhat?
    Canadian HI-fi I heard is a good dealer a warranty and a through check out before you buy from them.
  • PolkieMan
    vcwatkins wrote: »
    Craig
    After I was your comment I checked them out lots of power on tap and good reviews https://www.youtube.com/watch?v=GujALveqXAY
  • PolkieMan
    Jesse, so you weren't really impressed all that much, it was somewhat okay to kinda cool ?
  • boston1450
    boston1450 Posts: 7,758
    I have the Yaqin ms30l its hooked to the Monitor 11's & its total bliss on alot of music i listen to such as Clapton Santana piano/instrumental & more. I have wanted to try them on the 1c's but it sounds so good on the 11's. I wouldnt hesitate to try. There are a few here that have that amp & for the price its a great foot in door to tubes
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Mikey081057
    Mikey081057 Posts: 7,127
    xcapri79 wrote: »
    @Mikey081057 uses the YAQIN MC-100B with his SDA's
    So i plugged my sda's into my 100b and am wicked impressed. easily reaches reference levels in triode mode and rocks the hood!
    There are some discussions on this that you may be interested in.
    http://forum.polkaudio.com/discussion/161855/silk-audio-100b-tube-amp
    http://forum.polkaudio.com/discussion/163137/window-shopping-yaqin-tube-amps
    So I have used my MC100B with my SDA SRS 2.3's and they sounded really sweet with plenty of slam. I currently use my Parasound P5 and A21. Tubes and SDA's sound great together but my Parasound rig gets the nod... for about 4x the price.
    Garage | Polk Monitor 5B's
    F1nut Posts: 51,809
    PolkieMan wrote: »
    Sorry, I meant I have no experience with that piece, but plenty with other tube gear.
  • PolkieMan
    Have you had good service with your MC100B?
    I hate to get into something that is going to give me a headache :)
    xcapri79 wrote: »
  • PolkieMan
    So Randy you think it would be (ms30L) enough power for the 1C. Is it common ground?
    boston1450 wrote: »
  • boston1450
    I have not checked. I heard somewhere it could be used & its has enough power to do the job. Ive never been above 9:30 with it since ive owned it. I can easily try it out & get back to you.Take me 2 mins to try. Let me get back to you tonight after a hour of listening
    Randy-Maine
    by David WMG
  • nspindel
    nspindel Posts: 5,343
    Another option you can consider is a solid state amp and a tube pre-amp, that's what I do. I have a Krell KAV-2250 amp, solid state, paired with Dared MC-7P. I love it.
  • boston1450
    nspindel wrote: »
    thats what i want to do with my Denon POA-2200 ive heard nothing but good there
    Randy-Maine
    by David WMG
  • boston1450
    Well hooked up the 30L & 30A tube cd player & cheesy Arrow Red Cables (soon to be gone) & listened to Eagles & was floored. Sounds sweet. Brought the dial up to 10:00 around 90dbs+ with burst on iphone meter. Plenty of power. Bass seemed better on the 1c's. Rd0's sound excellent. Focused tones. Very nice. I almost think i may keep it set up like this for awhile :smile: i have not rolled tubes in this yet & with stock ones it sounds very good. I have other tubes to roll but ive been enjoying the stock ones too much to mess with it yet....vcs926gzm0kh.jpg
    The 1c's were hooked to Denon POA2200 @ 200+ wpc@8ohm with a Denon DRA1200 preamp w/mit speaker cables-bjc ic's.... One thing to note. The other Yaqins may have meter to adjust tubes. The 30L you need meter. I wish i had bought this when i first started this hobby. Best purchase yet-besides cables
    Randy-Maine
    by David WMG
  • Simplyrandom
    Simplyrandom Posts: 119
    Dammit Boston now you have that Yaqin tube cdp staring at me whispering take me home.
  • PolkieMan
    Very nice Randy. So the 30L is plenty enough for the 1C's and it is common ground I assume.
  • PolkieMan
    What I want to get to or at least really try out is an all analog system consisting of Turntable, tube phono preamp and tube preamp/amp and SDA's. I know it sounds nuts but it's something I've been wanting to do.
    nspindel wrote: »
  • nspindel
    edited May 2015
    It starts getting substantially more complicated when you have multiple pieces of tube gear. You get into synergy issues very quickly. Too much of a good thing can be a problem. Many find it is more than adequate to just get one piece of tube gear in somewhere in the chain, and the preamp to me has always seemed like the logical place to do it. Having a solid state preamp provides all the bass slam you'd want, but with the tube warmth from the preamp. Great combination.
    Post edited by nspindel on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    PolkieMan wrote: »
    Plenty of power for 1C's and my SRS 1.2TL's as well. It's common ground. Excellent sound quality for the money.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • voltz
    voltz Posts: 5,384
    I have the MC100b along with Marvin & Mikey & Faustin who is selling his in the FM. think he near Chicago. it is a 70lb brute. I've powered my monitor 10's & CRS's with it and really like this thing. It uses KT88's
  • Emlyn
    Emlyn Posts: 4,735
    My approach has been to use an older Classe Model 25 solid state amp. Comes pretty close to the tube qualities I like and avoids those I don't. Actually, very similar to a Sonic Frontiers Power 2 tube amp I have which uses 6550 or KT88 tubes. That tube amp isn't a common ground design.
  • PolkieMan
    So it's common ground also? (YAQIN MC-100B)
    Are most all of the Yaqins common ground?
    voltz wrote: »
  • voltz
    voltz Posts: 5,384
    edited May 2015
    I hook my meter to both the of the Negative binding post and it read 000.1 which if I am doing it right should make it common ground. also Mikey has used this amp with his SDA 2.3's I sure I had used it on my CRS+'s but I have them dismantled right now and can not recheck it. -> this was on my MC100B
  • michaeljhsda2
    Yes the 100B is common ground. MC10L, 20L, 30L, MC10T are as well.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • PolkieMan
    Thanks gents something else I don't have to contend with.
  • vcwatkins
    vcwatkins wrote: »
    Well FWIW, I ended up keeping the tube pre/solid state amp combo with the SRS1.2's as in my sig. Just really hard to beat the Sunfire Sig II's 625w@8, 1250w@4 on the big boys with the lovely Belles pre. Authoritative, tight bass and better detail on top (this is an otherwise warm rig). Had a bit of smearing and ringing with the Cronus there.
    BUT, the Cronus-Maggie 1.6 pairing is a glorious jazz rig (sans subwoofer). I will need to give some thought to how to best use that combo. Wishing the Cronus had a HT bypass. (sigh)
