Rubber feet for RTi10's
My family room has berber carpet and I currently have a pair of RTi10's with the spikes. However, the wife is insisting on replacing the carpet with ceramic tile, so I think I'll have to replace the spikes with rubber feet. Anyone know where I can get some that will screw into the holes where the spikes are now?
Post edited by Mikey_C on
You may want to check your local home depot or lowes.
They have a section, I believe where the chair casters are located, that contains various rubber feet - some with studs. Not sure if they are the right size - but is worth a shot. -
Why not get some spike footers? See audio advisor.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Here's one example:Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Try Polk. Call CS and ask them. Not sure, but maybe the screws and the rubber feet for the RTi70's will fit the RTi10's too, so it's worth a try. Several months ago I needed rubber feet for my 70's and Polk shipped them to me free of charge.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
