Rubber feet for RTi10's
Mikey_C
Mikey_C Posts: 13
edited August 2004 in Speakers
My family room has berber carpet and I currently have a pair of RTi10's with the spikes. However, the wife is insisting on replacing the carpet with ceramic tile, so I think I'll have to replace the spikes with rubber feet. Anyone know where I can get some that will screw into the holes where the spikes are now?
  • par-man
    par-man Posts: 14
    edited August 2004
    You may want to check your local home depot or lowes.
    They have a section, I believe where the chair casters are located, that contains various rubber feet - some with studs. Not sure if they are the right size - but is worth a shot.
  • steveinaz
    steveinaz Posts: 19,547
    edited August 2004
    Why not get some spike footers? See audio advisor.
  • steveinaz
    edited August 2004
    Here's one example:
  • Early B.
    Early B. Posts: 7,900
    edited August 2004
    Try Polk. Call CS and ask them. Not sure, but maybe the screws and the rubber feet for the RTi70's will fit the RTi10's too, so it's worth a try. Several months ago I needed rubber feet for my 70's and Polk shipped them to me free of charge.
    "God grooves with tubes."
