BR plug-in for ripping BRA?
obieone
With my latest PC build, I installed a BRD drive, and was wondering if there is any software available for ripping BRA?
I've got Cyberpower DVD installed, but I don't know if there's any plug-ins for it?
Thanks for any feedback
I have never done that process but here's a detail way in doing it:
computeraudiophile.com/content/473-ripping-blu-ray-easy-way/
OlivierMain System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Receiver: Pioneer VSX-1121k
Amp: Carver AV 705x
TV: Samsung LN52A650
Media Player: Chromecast/Boxee Box
BD Player: Sony BDP-S470
Consoles: Xbox360, Wii U -
That works. I posted a thread a while back on how to do this. However, it only works on Blue Ray Audio disks. You can't get the audio of a concert Blue Ray, for example.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
that makes sense. I believe you might have to do something like this: rip BR to mkv, then use something like mkvmerge to export the track. I'll try to find some info later on. I believe the doom forums would be your best place to figure it out.Main System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Amp: Carver AV 705x
https://www.youtube.com/watch?v=G7gHhLH4swM
