BR plug-in for ripping BRA?
obieone
obieone Posts: 5,077
With my latest PC build, I installed a BRD drive, and was wondering if there is any software available for ripping BRA?
I've got Cyberpower DVD installed, but I don't know if there's any plug-ins for it?
Thanks for any feedback
  • cascius
    cascius Posts: 179
    I have never done that process but here's a detail way in doing it:
    computeraudiophile.com/content/473-ripping-blu-ray-easy-way/
    Olivier
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Receiver: Pioneer VSX-1121k
    Amp: Carver AV 705x
    TV: Samsung LN52A650
    Media Player: Chromecast/Boxee Box
    BD Player: Sony BDP-S470
    Consoles: Xbox360, Wii U
  • BlueFox
    BlueFox Posts: 15,250
    That works. I posted a thread a while back on how to do this. However, it only works on Blue Ray Audio disks. You can't get the audio of a concert Blue Ray, for example.
  • cascius
    cascius Posts: 179
    that makes sense. I believe you might have to do something like this: rip BR to mkv, then use something like mkvmerge to export the track. I'll try to find some info later on. I believe the doom forums would be your best place to figure it out.
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Amp: Carver AV 705x
    nooshinjohn Posts: 26,002
    Is this the BRA rip you are speaking of?
    https://www.youtube.com/watch?v=G7gHhLH4swM
