Larry Rings
    nooshinjohn Posts: 25,984
    Once again, if the original gaskets are not damaged there is absolutely no reason to replace them. If they are damaged and you don't feel like hacking up a bunch of Armacell, Parts Express sells 1/2" wide foam gasket tape.
    The stuff from P/E does not compress as well as the Armacell, from what I have been told. I think DK found that as well when he did that massive three-way trial.
    F1nut Posts: 51,951
    Ah, very good. I haven't used it, just saw it in the catalog.
