Passive Preamp Project - Help?
ambiophonics
ambiophonics Posts: 727
edited April 2015 in DIY, Mods & Tweaks
I'm in the process of building a passive preamp to try out in my system. I have most of the parts ordered including a ladder type stepped attenuator but am having a hard time understanding how to properly choose the value of the stepped attenuator. It seems its a trade off between possibly loading down the source or high frequency roll off. I don't understand all of the math involved in figuring this out despite extensive reading online. Anyone care to help shed some light on this issue? I'm happy to elaborate on my specific system specs and what I've read/found so far.
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
    mhardy6647 Posts: 35,121
    edited April 2015
    edit: I'm sorry, bur my knee-jerk answer wasn't adequately correct enough to be helpful.
    Did you look at this design? http://diyaudioprojects.com/Misc/DIY-Stepped-Attenuator/
    EndersShadow Posts: 17,713
    DIYAudio may be a better place to post... lots of DIY guys there......
    I'm sitting on a cool little DIY Pass Pre-amp myself with a stepped ladder resistor volume knob. Its gonna go into the closet for later as I've got a nice older HT Pre-amp incoming so I've got volume control.
  • mhardy6647 wrote: »
    That's funny, I saw that post earlier and left a comment - just got a detailed response on the guys site and a separate personalized email response from him. Seems like a very nice guy.
    Looked like he knew what he was talking about, as well.
    Impedance matching is is the big trick to passive "preamplification" (at least, as I understand it). I'm curious -- did you consider using a tapped transformer or autoformer for attenuation rather than a stepped resistor-based attenuator? See, e.g., www.intactaudio.com
    (that's the route I went, FWIW -- the autoformer volume control seems more transparent to my ear)
  • The autotransformers look great but they're a bit outside of the budget for this build. I'm only going to spend about $100 total on this build just so I can see if it really makes a noticeable difference.
    If you have enough drive from your source component for the power amp and if the impedance match from source to power amp is good... it will :- )
  • ambiophonics
    edited April 2015
    Here it is! Still needs some labels for the controls and rear panel but it's ready to go otherwise. The stepped attenuator took forever to arrive from Taiwan and then was not the same type I ordered. I ordered a ladder type 100k with KOA 1% resistors and was sent a series type 100k with Vishay SMD precision resistors. I was given a refund for the part the sent me so I decided just use that for now. I have inputs for CD and Phono plus a home theater bypass input that doesn't go through the volume control. The 3 position switch chooses between the three inputs. If anyone is interested I'll include the resistance measurements of each volume position below. Seems pretty closely matched and much better than the volume pot I removed from the TFM-35 which was pretty inaccurate in the lower range.
    Left Channel
    99.6k
    99.1k
    98.9k
    98.7k
    98.5k
    98.1k
    97.7k
    97.2k
    96.5k
    95.7k
    94.7k
    93.4k
    91.8k
    89.6k
    87.2k
    83.9k
    79.6k
    74.5k
    68.3k
    60.1k
    49.1k
    36.1k
    20.0k
    00.2ohms
    Right Channel
    99.6k
    99.1k
    98.9k
    98.7k
    98.4k
    98.1k
    97.7k
    97.1k
    96.5k
    95.6k
    94.7k
    93.4k
    91.8k
    89.6k
    87.2k
    83.9k
    79.5k
    74.4k
    68.3k
    60.0k
    49.1k
    36.1k
    20.0k
    00.2ohms
    It looks absolutely terrific.
  • Everything is plugged in now and it sounds really transparent - most noticeably things sound really good at low volume, excellent imaging, tight deep bass. I've only heard a few tracks so far and can't crank it up tonight.
    "Transparent" is what the passive attenuators do, IME. There's the aforementioned (potential) trade-offs of no additional gain stage nor impedance matching (buffering) but the relative merits of passive vs. active just have to be evaluated empirically, I'd opine.
    Have fun!
  • steveinaz
    steveinaz Posts: 19,545
    I have a Placette passive (vishay) and love it. Transparency off the charts, and outstanding linearity at any level.
