pre outs on kenwood
Willow
Willow Posts: 11,257
edited August 2004 in Electronics
I have pre outs on my kenwood I also have a sansui stereo receiver. Can I link them up for better sound ? what should I look for behind the kenwood so I can be sure it can be linked to the sanui
thanks
Post edited by Willow on
  • pjdami
    pjdami Posts: 1,894
    edited August 2004
    What is the kenwood? Another receiver? I wouldn't try to hook up two receivers. Just go with the one that sounds better to you and enjoy the other receiver in another room.
    What are you trying to improve? Do you need more power?
    Paul
  • Willow
    edited August 2004
    yes I wanted to use one to power the fronts and the other the rears...not worth it in this case ???
