pre outs on kenwood
Willow
I have pre outs on my kenwood I also have a sansui stereo receiver. Can I link them up for better sound ? what should I look for behind the kenwood so I can be sure it can be linked to the sanui
thanks
thanks
Post edited by Willow on
What is the kenwood? Another receiver? I wouldn't try to hook up two receivers. Just go with the one that sounds better to you and enjoy the other receiver in another room.
What are you trying to improve? Do you need more power?
Paul -
yes I wanted to use one to power the fronts and the other the rears...not worth it in this case ???
