EQing 2 channel
fyrn
Question for the 2 channel guys. I have a 2.1 system but my preamp does not have bass management. Anybody using a stand alone EQ for room equalization, like you would when using a receiver with audyseey or the likes? Any suggestions, thanks
Put on you cast iron drawers....may get rough.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
LOL - that was funny stuff... and no - no equalizer in my 2CH. I think that's generally considered a no-no but I could be wrong. Unless we're talking bass management from SACD players?VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
When I 1st got into 2 channel music my I started with a Peachtree Integrated amp that had no tone controls, and I think as you get better equipment and cables the need for tone controls goes away and you find they are not need anymore!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Most 2 channel guys don't have a need for bass management. It will add a level of noise to the signal those equalizers. But....if it floats your boat many can be had for 20-40 bucks on craigslist so not like you have to mortgage the farm to try one out.HT SYSTEM-
lsi 9's -
I'm talking strictly for bass management, The 703's have a bump at 50hz and when you add a sub its really pronounce. The ideal solution would be to buy a preamp with bass management but that's a little pricey, so hence the question of the stand alone EQ, to accomplish the same thing (sort of). Or does anyone make an external low pass filter? Welcoming suggestions.
I'm not sure what your source is, but I have a room that really needs larger speakers the my MD2's so at I often lack bass. If I am going to EQ my system I prefer doing it from the source i.e. my Jrivers media. This also helps be correct poor recordings for a more enjoyable listening session....basically reproduction of a track without implementing more noise/distortion is my electronics chain.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Anti-Mode 8033 for sub EQ...superb piece.
