EQing 2 channel
Question for the 2 channel guys. I have a 2.1 system but my preamp does not have bass management. Anybody using a stand alone EQ for room equalization, like you would when using a receiver with audyseey or the likes? Any suggestions, thanks
  • vmaxer
    vmaxer Posts: 5,121
    Put on you cast iron drawers....may get rough.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • MrBuhl
    MrBuhl Posts: 2,419
    vmaxer wrote: »
    LOL - that was funny stuff... and no - no equalizer in my 2CH. I think that's generally considered a no-no but I could be wrong. Unless we're talking bass management from SACD players?
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • voltz
    voltz Posts: 5,384
    When I 1st got into 2 channel music my I started with a Peachtree Integrated amp that had no tone controls, and I think as you get better equipment and cables the need for tone controls goes away and you find they are not need anymore!
    Most 2 channel guys don't have a need for bass management. It will add a level of noise to the signal those equalizers. But....if it floats your boat many can be had for 20-40 bucks on craigslist so not like you have to mortgage the farm to try one out.
  • fyrn
    fyrn Posts: 146
    edited April 2015
    I'm talking strictly for bass management, The 703's have a bump at 50hz and when you add a sub its really pronounce. The ideal solution would be to buy a preamp with bass management but that's a little pricey, so hence the question of the stand alone EQ, to accomplish the same thing (sort of). Or does anyone make an external low pass filter? Welcoming suggestions.
    txcoastal1 Posts: 13,519
    I'm not sure what your source is, but I have a room that really needs larger speakers the my MD2's so at I often lack bass. If I am going to EQ my system I prefer doing it from the source i.e. my Jrivers media. This also helps be correct poor recordings for a more enjoyable listening session....basically reproduction of a track without implementing more noise/distortion is my electronics chain.
  • pearsall001
    pearsall001 Posts: 5,329
    Anti-Mode 8033 for sub EQ...superb piece.
