Fuses on vintage speakers
Zenkman
I have a pair of Vintage Monitor 10s with the double fuses. The fuses need to be replaced, but I cannot read any information on the old fuses. What type of fuse is needed. Are the top and bottom fuses the same....any help would be appreciated.
1A fast blowafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
The top fuse is for the Tweeter, so 1 amp fast blow.
The bottom fuse is for the woofers. I'm guessing 3 amp fast blow.Home Theater/2 Channel:
dhsspeakerservice.com/ -
My RTA 12C's came with 0.75 amp fast blow. Not sure how much difference it makes, but I'd be cautious protecting the tweeter section with a 1 amp."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I remember reading an old RTA-12 review that said 0.75 amp, I was wondering about that. I wonder if it's to account for the fact that cheap fuses aren't exactly accurate.drumminman wrote: »My RTA 12C's came with 0.75 amp fast blow. Not sure how much difference it makes, but I'd be cautious protecting the tweeter section with a 1 amp.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Thanks for all the great input. Can you please explain fast blow. Is that different than a normal type of fuse. Would I have to ask for it by name. Does it really matter if it is a 1A 2A or 3A fuse.
You could bypass the fuses all together (or put in a much higher amp fuse) if you wanted, you just run the risk of frying your drivers if you run your amp into clipping. Having the correct fuses is a safety net.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
That helps a lot! Much appreciated.
If you look at the original Monitor 10 schematic, which was for the Peerless tweeter, it specifies a 1A Fast fuse. When I rebuilt a pair of 10A's I used these:
http://www.amazon.com/gp/aw/d/B000CZ2YRUGood music, a good source, and good power can make SDA's sing. Tubes make them dance. -
My recently purchased 10B's have weak polyswitches and I am not ready to do the XO upgrade yet. Can I short the polyswitch by twisting it and put a .75 or1 amp fast blow inline fuse on the positive wire going to the tweet for protection until the rebuild?
After reading the different post on the upgrades I didn't hear anyone speak of replacing the wire from the XO to the speakers, why would this not be done while in there?
And if I put an inline fuse for the tweets could I put a 2.75 or 3 amp fast blow in for the mid woofers also?
You may ask why all the protection? I have lower power amps 125w max and teenagers that have access to this set-up and I sometimes have drunky ears while listening myself. Not doing the XO upgrade yet leaves a fair amount of change for the purchase of a better amp which is higher on my list as I have other speakers that I am wanting to put some real power behind.
Any advice on the technical aspect of this is appreciated. Though I expect some comments on the teenagers and drunken ears to be forthcoming.
Thanks, Cooley. -
Thanks, Cooley.
The are post in regards to the internal speaker wire upgrades.
I have done it, but honestly, it's such a short distance. Unless the exiting wiring is corroded or damaged, it would be hard to notice any other improvement than aesthetics.
Post edited by cortico on -
Thank you very much.
Cooley -
cortico is correct I second that. When I did my SDA's I did redo the wire it was because the former owner had tried to make them something they were not....lots of splices...
