AES/EBU cable
any strong feelings on these. Forget it and just go Tosalink?
recommendations?
  • BlueFox
    BlueFox Posts: 15,250
    Generic advice is that optical introduces two additional stages of possible distortion; electrical to optical conversion, and optical to electrical conversion.
    AES digital probably does not make much difference until you get into higher end, more revealing gear. Even then, it probably is minor. Just depends on how much detail you are trying to extract.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Thanks Bluefox! I'll put that to rest for now.
    Digital coax would be my preference .
  • [Deleted User]
    edited March 2015
    Thanks Tonyb. That I can try. That was my choice on the ole NAD 5440
    If I may suggest, the Blackcat Veloce digital coax on the used market runs around 50-80 bucks, none better imho for that price.
  • [Deleted User]
    yes you may, thanks!!
