AES/EBU cable
any strong feelings on these. Forget it and just go Tosalink?
recommendations?
recommendations?
Generic advice is that optical introduces two additional stages of possible distortion; electrical to optical conversion, and optical to electrical conversion.
AES digital probably does not make much difference until you get into higher end, more revealing gear. Even then, it probably is minor. Just depends on how much detail you are trying to extract.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Thanks Bluefox! I'll put that to rest for now.
Digital coax would be my preference .HT SYSTEM-
lsi 9's -
Thanks Tonyb. That I can try. That was my choice on the ole NAD 5440
If I may suggest, the Blackcat Veloce digital coax on the used market runs around 50-80 bucks, none better imho for that price.HT SYSTEM-
lsi 9's -
yes you may, thanks!!
