HK3490 Left Channel Volume Issues
PerfectCreature
As most of you are aware I have had the pleasure of enjoying the Harmon Kardon 3490 stereo amplifier for the last few years.
Unfortunately I am stricken with an issue I cannot figure out.
The left channel will on occasion, without reason and without any indication on how to reproduce this particular issue, fall short in volume compared to the right channel.
I have swapped my cables and my speakers around. Still on the left channel.
I swapped the A output and the B output thinking it may have been a bad post.
The issue still persists.
Does anyone have any clues as to what might cause the left channel alone to distort on occasion, and have a reduced volume compared to the right channel on a whim?
It has only cracked and blipped once, but has as of late started to produce this issue more and more. Either that or since I have become aware I am noticing it more and more.
I was considering getting it repaired, but I have no HK sourced repair centers even close to where I live.
I appreciate the help!
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I have made some calls, Harmon Kardon is unwilling to help, they just keep telling me get it serviced at a repair center that is 7.5 hours away. I called the center and was told they no longer service Harmon Kardon.
I guess I may have to purchase a new receiver. I am quite alarmed that after only 4 years of ownership it has faulty parts.
I have contacted several local electronics repair shops and they all stated that they are not familiar with them and indicated an unwillingness to repair.
I am wondering if this could be something that could be tackled by myself?
Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
I know they are fairly stout, which is why I am confused. I am going to do some more tests and see if I can repeat the issue. I spoke to one repair facility who stated he could probably do the repair (it would require a nonrefundable $50 deposit, and an hourly labor fee and the cost of the "premium" parts as he called them) but would need to special order the proper parts from Harmon Kardon if I wanted the same quality parts, as he stocks generic parts.
He mentioned changing the source, tapping the unit, and lightly knocking it down to see if that would remedy the issue.
How do you know it uses digital volume control, could it be a software issue perhaps? I wonder resetting it will fix the issue.. I know I have the most current software, as it was built in 2010 and it was confirmed the software is the most up to date.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Interesting, I had noticed that, now that you mention it, that makes sense. I had a older Teac receiver that used to hit a max point and min point.
As far as the left and right. I will fiddle with it, see what the balance does.
Would you have an idea as to what would be considered strange, possibly what I should look for?Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Okay, I have built a few computers, so I am familiar with the "try not to touch".
I will take some photos and upload them, perhaps some individuals who have fiddled more deeply into upgrading and repairing circuit boards could chime in.
I have a nice Fenix torch light that should be plenty bright enough.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I appreciate the condolences, I just would love for it to go back to its normal ways.
In retrospect, if this proves to be a hassle, I will just pick up a small HT receiver, and tuck it in the closet or sell it for someone else to fix and enjoy.
I've been heavily considering a Marantz 1403, it will be a significant step downward in terms of power, but should be in improvement in terms of listening experience due to the Audessy EQ and the ability to get a true 5.1 instead of just tossing the HK in reference mode for that surround effect.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
I tried tapping and shaking the receiver and it did not cause any changes.
My wife stated it has been acting up all day yesterday.
It hasn't seemed to do anything yet.
I will next try changing the input and see of what that does.
I plan to open it up and see if I can notice anythingReceiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
It has not acted up today. It ran for a few hours at various levels.
I am wondering if smacking and shaking the the unit up and down actually did anything....Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Not entirely sure what it is. It has not done anything close to what it had been doing. I shook the receiver and lifted and dropped it up and down with a small thud a few times and reconfirmed all the connections.
I cannot be certain that all the issues were due to something that was connected wrong or loose.
In any case, It appears to be okay for the moment.
I will update if any issues arise.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
