How are you guys streaming into your DACs?
How are you guys streaming from your networks? I was looking at a cdp with digital inputs and was not sure if a USB input was something that was imperative nowadays or would any kind of input (toslink or spdif) be sufficient? What are your choices for streamers?
    tonyb Posts: 33,072
    I use a digital coax into my dac. Which cdp you looking at ? The Cary pro 306 ? DK uses one and has compared it to many others who have yet to dethrone it.
  • Joey_V
    Joey_V Posts: 8,600
    306 sacd which is I think similar to pro.
  • Joey_V
    Joey_V Posts: 8,600
    Tony
    What's your streamer?
  • Moose68Bash
    Moose68Bash Posts: 3,843
    I stream music to two PS Audio DACs -- a PerfectWave MKII and a DirectStream -- via my household LAN (Linksys WRT1900AC router and CAT 6 cable). Music files are all (at this point) AIFF files stored on a Synology DiskStation 713+ with two 4TB from Western Digital ("Reds" I believe).
    tonyb Posts: 33,072
    Joey_V wrote: »
    Tony
    I'm just using a sonos for now. 16/44 is all it's capable of. I don't buy SACD's or download hi-rez so it works for me.
    If I had to do it all over again, I might go with a Blue sound unit. DK, who has a Cary 306 is using a Bryston for his streamer and he's tickled pink with it. You can find his review in the digital section.
    EndersShadow Posts: 17,704
    I'm using a DacMagic and am using coaxial into it from my computer rather than USB. Mostly due to the fact I get a higher bitrate into the DAC w coaxial.
  • Joey_V
    Joey_V Posts: 8,600
    Ah I see. Straight from the soundcard
    Joey_V wrote: »
    Basically. My motherboard has coaxial and optical outputs... The optical is broken though so I can't use it.
  • voltz
    voltz Posts: 5,384
    edited March 2015
    I using the DAC in my Marantz SACD player from my Pc using USB and a window driver I got from Marantz. can do DSD this way. and I use JRiver media also.
  • recoveryone
    recoveryone Posts: 929
    Still using SB throughout the house via LMS Wifi
  • Wardsweb
    Wardsweb Posts: 942
    I run JRiver on a PC that is USB to my Music Fidelity M1DAC. I also run a coax from my CDP to the DAC.
  • PSOVLSK
    PSOVLSK Posts: 5,382
    USB straight to my Peachtree Nova in the computer room. Everywhere else I'm wireless.
  • brianle
    brianle Posts: 572
    Laptop to Benchmark DAC 2 via USB
  • BlueFox
    BlueFox Posts: 15,251
    Are we talking about streaming services, such as Tidal, or just playing ripped audio files?
    msg Posts: 10,452
    ..My motherboard has coaxial and optical outputs...
    which motherboard is that, out of curiosity?
    msg wrote: »
    It's an oldie.
    Asus P5E. I should mention this is off a desktop computer
    msg Posts: 10,452
    interesting. I didn't know they made them like that; I've been loosely considering building something and have been looking casually for sound cards... always did like the Asus stuff. pretty solid and usually pretty peppy.
    msg wrote: »
    Most non oem motherboards have optical or coaxial outputs nowadays
  • Nightfall
    Nightfall Posts: 10,084
    edited March 2015
    Asus laptop running Ubuntu Linux > FLAC (most is 24/96 and some is 24/192) > HDMI > Yamaha Aventage (24/192 Burr Brown)
    Saving money and putting together what I want is slow, there's other things I need more than a stand alone DAC. I started from nothing about a year and a half ago, it's coming along.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • deucekazoo
    deucekazoo Posts: 146
    Foobar2000 on PC running into a Emotiva DC-1using USB.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • erniejade
    erniejade Posts: 6,321
    usb to a w4s dac2 for now.
  • machone
    machone Posts: 1,559
    I just received my Korg DSDAC-100. I am using Korg Audiogate 3.0.2 on a Dell Precision M4400 laptop to the Korg DSDAC-100 via USB. I upconvert everything to DSD 5.6mhz. It sounds great!! and this is with upconverted CDs! I just got it so I have not had time to download DSD files created straight from a master. Very natural sound; vocals, brass, strings, bass, everything and with great dynamics! The "digital" edge seems to be gone. Very impressed with the Korg and with DSD.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Moose68Bash
    edited May 2015
    When I posted the above, I neglected to say that I use the DiskStation Manager ("DSM") and Audio Station software that came with the DiskStation 713+.
    DSM and Audio Station have severe limitations (IMHO) that I would like to overcome by installing different software to stream the music.
    At this point I wouldn't recommend my set up, and I'm looking to find an alternative.
  • Jetmaker737
    Jetmaker737 Posts: 1,118
    FLAC to SBT then thru coax to Rega DAC.
  • btown1985
    btown1985 Posts: 113
    USB to my Oppo, simple enough and sounds great
    LSiM 705 and 706c, Def Tech Supercube I, Anthem AVM20 Processor, Oppo BDP-105D, Adcom GFA-5503, Pioneer Kuro KRP-500M, Panamax Elite 15PFi
  • vcwatkins
    vcwatkins Posts: 1,993
    Library is on USB3 HD attached to networked PC and WD NAS (backup & cloud).
    Primary system uses Squeezebox devices: 5 Touch's, a PC, an Amazon FireTV, and an iPhone. Two Touch's, the FireTV, and the PC use separate DACs. Touch-to-DAC is coax. PC-to-DAC is USB. Others are analog to preamp.
    Music player app > Remote app > Stream Device > Cable > Dac
    Primary system:
    Logitech Media Server (LMS) > iPeng > SBTouch > Coax > Dac
    LMS (Squeezelite) > iPeng > PC > USB > Dac
    LMS (SBPlayer-turns FireTV into SB) > iPeng > FireTV > Optical > Dac
    LMS > iPeng > iPhone
    Secondary systems:
    JRiver > JRemote > FireTV > Optical > Dac
    Airplay/DLNA Player Pro > MacBook Air > FireTV > Optical > Dac
    Oppo (browse files directly on network) > Optical > Dac
    tonyb Posts: 33,072
    I have Chuck Norris simply tell it to go there....and it does.
  • Joey_V
    Joey_V Posts: 8,600
    tonyb wrote: »
    bwahahaha
  • Irrenhaus
    Irrenhaus Posts: 1,103
    Via USB to the TEAC DAC from a Intel NUC MiniPC. A combination of MP3's and hi rez files.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • vc69
    vc69 Posts: 2,500
    edited May 2015
    I'm using a Squeezebox as a wireless transport to my Musical Fidelity M1 DAC via coax (spdif) and my buddy is using jRiver via Cat5 to his Perfectwave II w/bridge.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
