Need Power???
  • exalted512
    exalted512 Posts: 10,734
    edited August 2004
    agreed with macleod
    -Cody
  • cpmzx3
    cpmzx3 Posts: 9
    edited August 2004
    What about the Xenon series from PG?
    Pioneer Premier DEH-P860MP
    2 Polk Audio MM2124's
    More to come...
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2004
    Personally I like the Titanium series better. They had awesome specs (THD .001% - SNR 110 db) and looked great. The main gripe I have with the Xenon series is that they are fully regulated. In other words they put out their rated power at all impedances. That in itself isnt that bad but regulated amps tend to not have quite as much headroom than an unregulated type. The difference would be seen in the slap of a snare drum. A regulated amp would play that slap at the same power as the rest of the frequencies. An unregulated amp would play it at higher power making it cut thru the rest of the music as it should and thus be more relasitic. Headroom also adds a great deal to detail.
    Not that this makes it a bad amp. JL Audio Slash series and all Xtant amps are regulated and I dont think you could find too many people (outisde of Sinton TX :p ) that would consider either of those to be sub-par amps.
  • exalted512
    edited August 2004
    i live in college station, and JL sucks
    -Cody
