Audiophile Quality Tube Audio Design TAD-60 Amplifier
Mystery
For sale is excellent condition Audiophile Quality Tube Audio Design TAD-60 Amplifier.
Serious inquiries only.
$950+shipping. PP gift or USPS MO or pay fees.
Here is a review on this amplifier:
http://brianmedia.net/2013/04/tube-audio-design-tad-60-amp/
Audiogon Review: Tube Audio Design TAD-60 Tube amp:
http://forum.audiogon.com/cgi-bin/frr.pl?ramps&1129061242&3
I'll start by saying that I've been into higher-end audio for a few decades now, and quite a lot of equipment has been through my hands to this point (half the fun of this hobby). Somewhere around 12 years ago, I'd come to realize that I preferred tube amplification over solid state in terms of an overall involving presentation of the music, and ever since then have owned tube stuff (brief flirtations with various solid state devices only helped to enforce this notion).
Which brings me to the discovery of Tube Audio Design, the provider of components conceived by Paul Grzybek (of Bizzy Bee Audio fame), built to his specifications by a very reputable Chinese manufacturer, and then hand-finished by Paul in his shop located in Wheaton, IL. (His offerings are available exclusively online; detailed product info is found at www.angelfire.com/biz/bizzyb/i...)
The TAD-60 amplifier is built like the proverbial tank; overall appearance and heft (not to mention its specifications) in my experience indeed belie the modest asking price. With its stainless steel chassis and almost 1/2"-thick black anodized face, the relatively compact package portrays a masculine but elegant stance (also included is a lift-off stainless steel tube cage). All function controls are easily accessible from the chassis top, as are the tube bias test-points and adjustment pots (a digital voltmeter is included too).
EL34-based, the TAD-60 is rated at 60wpc in UL-mode, and 30wpc in switchable-on-the-fly triode-mode. Other standard features include adjustable input sensitivity and adjustable global feedback, adding flexibility to a host of possible preamp and speaker combinations (the input sensitivity control may also be used as a volume pot in a single-source direct input configuration).
Listening to the TAD-60 after the recommended 30 hour break-in period and beyond, the music really began to open up, and along with the TAD-150 preamp, I was experiencing just about every CD I spun in a whole new manner - I'm particular to small-ensemble jazz and female vocals - there was an in-the-room conveyence of the music that I found startling at times - present is deep, tight bass, a glorious midrange, detail, depth, and an overall natural presentation that allows hour after hour of enjoyable listening. I've found that the feedback adjustment permits a fine-tuning of balance between dynamics and warmth, and was able to "lock in" the amp to my speakers for what sounds to be a perfect sonic match (just a tad of feedback along with the triode-mode setting seems to be the magic spot in my case).
Without attempting to describe every sonic attribute I'm hearing (though I'm happy to answer any particular inquiries), suffice it to say that the TAD-60/TAD-150 combination strikes a synergy and glow that is especially musical, and is among the finest I've had the pleasure of owning. The TAD-150 has already been highly praised in at least a few user and online reviews, and I bet the TAD-60 will soon be recognized as a similar standout. If you happen to be in the market for high quality, reasonably priced, excellent-sounding gear, just take a listen for yourself, and you will hear what these components can do for music. (Paul also offers a 15-day in-home trail period.)
Note: I have no financial interest or business relationship with Paul Grzybek or Tube Audio Design.
Associated gear
Magnepan 1.6QR, California Audio Labs CL-10, Music Hall MMF-5/Goldring G1012
Similar products
Conrad Johnson MV55
Sonic Frontiers SFS-40
VTL 50/50
Golden Tube SE-40
ASL AQ-1004
Sound Quest SQ-88
by Ggeers222 on 10-11-05
Associated gear
Similar products
Conrad Johnson MV55
VTL 50/50
Golden Tube SE-40
ASL AQ-1004
Sound Quest SQ-88
Man, it's been a while.
Best offers accepted on this.
I assume it comes with the original tubes? Do you have the TAD-150 Pre-amp?
Juan -
I have to check if it has original tubes or replacements.
Don't have the pre-amp.
The TAD-60 was my first tube amp, and I've been hooked ever since. This is an outstanding piece of gear, very vesital and responds well to various tubes.
Seems like it has Gain controls that let you elimitate a preamp if you like. -
Okay finally got around this.
More info and pics:
It's the later version with LED's for tube bias setup.
The smaller two tubes are GE JG-5814A.
The bigger four tubes are Electro-Harmonix 6CA7EH.
Forgot to check the smaller tube in between the big ones. Probably it's also a GE.
Cover comes off by lifting up.
Just pulled out from the cabinet where it was hooked up for months so don't mind the dust.
Pictures:
It's SOLD locally.
Here's a parting picture:
Gotta love pics of tubes in the dark! BTW - that Aragon is a beaut too!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Yep but my Sonus need little more power than the TAD-60 so using Aragon for them. Not tube like but pretty much comparable when running the TAD in bilinear mode.
Something we all learned at the San Diego get-together at Doug's place... TUBES RULE!
Somebody get froggy on this one as this is a nice looking piece, and a great way to get started in tube audio.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Something we all learned at the San Diego get-together at Doug's place... TUBES RULE!
No one can get froggy on this as it's already hopped away...
