Picked up some Monitor 7's
telemike
Picked up some Monitor 7's for restoration. Need to replace the SL2000 tweest and the grill cloth. Rosewood veneer. Wondering about a tweed or beige grill cloth? Think that might look good with Rosewood.
Good luck with the restoration. I think they would look spectacular with Rosewood veneer.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
That's the sweet spot in the Monitor lineup - congrats! You can order replacement tweets from Polk direct. Tell them you're a member for a discount.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
The cabs are rosewood veneer, a little chipped. I cleaned them and oiled them. Will do some more cleaning soon.
How do you clean the cones of dust? -
Windex. Real Windex. Not dollarstore/walmart kindRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
And don't spray on the cones.
Wet a piece of lint free cloth and wipe away...
Monitor 7's are great. Have a pair of early 7c from 1984 with the light oak wood veneer and the fuse on the back and the shorter grill cover with polk logo on the botton of the speaker cabinet. Also has the sl-1000 tweeters that most if not all polkies hate with a mad passion. Call me krazy with a k but with my old pioneer sx-1000td receiver from 1969, the sl-1000 tweeters sound like gold.Joey Ward
I thought that they were all "simulated" Rose wood VeneerPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Oak was also an option
Nice Score! Love my 7's
Joey, I'll tell you what, those SX1000 receivers are hidden gems. I have the Ta version (the earliest) hooked up to KLH Model Fives right now in my office and it does a superlative job. I will have to try it with my 10's.Citation 1, WOPL 400, Dynaco ST70, Pioneer SA9100, 5580, Marantz 4400
ADS 1590, AR9, Altec Santiago, Apogee Slant 6, KEF 104/2, Tannoy Mayfair, Allison One, Dahlquist M-907, JBL 4313b
Technics SL1015, Denon DP-62L w/103 -
I'm loving the Polk sound. Wondering about Monitor 10's someday
Many favor the 7's. post updates on how you make out.
Love them. Have some better condition grills on the way
I love my Monitor 7's. I've got a pair of the 7As with Peerless tweeters. They're an excellent sounding pair of speakers. I plan to eventually fully upgrade the crossovers and everything, but that's a long-distant future plan for now.
Definitely get those tweeters upgraded to the RD0 tweeter. It'll make a huge difference in the sound of your 7's.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
