Empire 598 II
Hello,
Been helping a friend get a classic Empire 598 II turntable working correctly. So far I've replaced the thin rubber support pad that goes on the tonearm lift plate and cleaned the cueing lift mechanism and added silicon to the damping friction clutch. Today I replaced the motor support grommets and sent him a photo and I thought I'd share it.
Beautiful machining on the motor pulley.
  • westmassguy
    westmassguy Posts: 6,850
    Awesome Ken
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • drumminman
    drumminman Posts: 3,396
    The base looks to be machined brass. What was the retail on that?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited February 2015
    For those who would like to know more about the Empire turntable history here is an Audiokarma thread:
    http://www.audiokarma.org/forums/showthread.php?t=278075
  • [Deleted User]
    edited April 2015
    Hello,
    All done and time to give it to my friend. The restoration involved repairing the cueing mechanism by adding a missing piece of thin rubber to the underside of the tonearm lift plate. The damping action, for the cueing, required cleaning the friction clutch and using the correct silicone between the plates. I replaced the drive belt and the main thrust plate bearing and added the correct lubrication after cleaning and polishing everything on the bearing. The motor suspension grommets were replaced also. Finally the cartridge was aligned using a Dennesen Soundtractor alignment protractor.
    The dust cover plexiglass panels were replaced (a tip of the hat to Total Plastics for providing the plastic and cutting it at no charge). All-in-all a satisfying project.
  • vcwatkins
    vcwatkins Posts: 1,992
    Gorgeous! Well done.
  • [Deleted User]
    Thanks, I appreciate the kind comments. One of the more satisfying things about this effort was the guy who worked in the plastics shop on Pulaski Highway. This place had been formally known as Garons Plastics and is now part of the Total Plastics company. I hadn't been in there for twenty years at least. I used to have plexiglass cut into sections that my dad would put together into dust covers for the Thorens/Rabco turntable my friends and I were marketing.
    This time the guy asked what the pieces were for and I explained how I was working on a friend's turntable. This prompted a nice conversation about his long gone record collection and how a few of his friends had dabbled on the edges of becoming professional rock musicians. One guy had even been a practice drummer for the visiting Rolling Stones on one of their Baltimore visits. In time the guy takes my original two sections of scratched plastic and goes into the stockroom looking for some scrap pieces he can give me.
    To mark time I start looking around the shop and see exhibits of 2" thick plexiglass used in security windows. Some are fitted with the round bullet proof "lazy Susan" used to exchange liquor for money in some of Baltimore's more unkind neighborhoods. After twenty or so minutes my new friend comes out of the stockroom with two perfectly cut pieces of smoked plexiglass and won't take a penny for his effort. I make some offers of paying and he brusquely refuses. I buy a bottle of plastic cleaner to put something in the till and off I go thinking about how getting to sit in with the Stones could be a hard act to follow in B-more.
  • vc69
    vc69 Posts: 2,500
    That table is absolutely gorgeous. A work of art, if I may.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited April 2015
    Wow! nice job. Thanks for the lead on the protractor as well. ;)
    How does it sound?
  • westmassguy
    Gorgeous Ken! Beautiful work.
  • voltz
    voltz Posts: 5,384
    Simply Stunning! Nice job!
  • MrBuhl
    MrBuhl Posts: 2,419
    Work of art indeed. Love the old tables!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    SCompRacer Posts: 9,121
    Nice work on an old classic Ken!
