Tight fitting banana plugs
Hello! I am having issues with my banana plugs. I am using Atlona Technologies 24k gold plated banana plugs and they just don't seem to fit tight enough. I am using 10 AWG wire and the weight of the wire pulls the plugs loose. Every few days I have to check all my connections and always find them loose and about to fall out. I am afraid that one day they will fall out, cross and short out the amplifier in my NAD receiver. I don't see how to fit spade connectors due to the room behind my components so I need to stay with banana connectors. What are you guys using? Which banana plugs seem to fit tight?
  • westmassguy
    westmassguy Posts: 6,850
    You need locking or expanding Banana plugs.
    There are high end models, but I find these to be excellent quality:
    http://www.speakerrepair.com/page/product/locking/BL8.html
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • mrloren
    mrloren Posts: 2,473
    Get the GLS locking ones or some good BFA plugs
    pitdogg2 Posts: 27,131
    mrloren wrote: »
    I'd scratch the BFA's as if he is having problems with the pairs he has now then it just might pinch the BFA's enough to be a bigger problem. I have used several different BFA's that didn't have the rubber in them and found them lacking big time. They all got looser as time went on and even when I tried to widen it didn't work well for me. Several times I came home to find them folded in half.
    I second the locking BUT I'd look for some 45 degree locking to relieve some of the pressure on the post
  • Alan_r
    Alan_r Posts: 164
    Ah, 45 degree. I see, the angle will relieve the leverage that is working the plugs loose. Unfortunately, I need plugs that come straight out due to clearance issues. However, the locking feature might do the trick. I will order two pair of the gls locking plugs and give them a try. I'll post the results for others. If they work I'll order the other 12. Thanks for the help guys. Alan
  • mrloren
    Good BFA plugs don't bend or come out, cheap ones well they are 100 yard targets.
    Locking plugs are better than cheap BFA plugs but do put a strain on the post.
