FS: Nice cheap clean vinyl, mostly classic rock and pop
I recently picked up a couple of small collections, including one from my brother. These are are mostly duplicates and others that aren't my cup of tea.
All have been cleaned on a VPI 16.5 and are play graded. I have listened to these all the way through. Most are original pressings and some are Canadian releases. If you need any deadwax info or a visual grade, just ask. All come with new poly inner sleeves. All inserts and inner sleeves are included if listed in the description. If you are not satisfied with your purchase, PM me and I will make it right.
I sold about 30 of these on Audio Karma without any complaints. You can check my feedback there under the same username.
Media mail shipping in brand new mailers is $5 for the first 2 records. Double LPs count as two. Add $1 for each two additional records. I have been informed that the USPS no longer charges for tracking as of 1/25/2015, so it will be included.
I accept USPS money orders and personal checks. I do not accept PayPal. Please post in the thread so others can see what is spoken for and send me a PM with your address.
cover/vinyl play grade
Pat Benatar ~ Precious Time ~ Chrysalis CHR 1346 ~ NM- in shrink, tiny scuff on binder edge, lyric inner sleeve has 1" split at bottom/VG++ occasional very light noise between some tracks ~ $3
Boston ~ self titled ~ Epic PE 34188 ~ VG+ few small binder edge scuffs and minor ring wear on back/VG++ minimal noise between some tracks, music sounds great, a real nice copy ~ $6
Boston ~ Don't Look Back ~ Epic FE 35050 (gatefold) ~ VG++ couple of minor edge scuffs, lyric inner sleeve has 2" split at bottom/VG+ occasional light noise between some tracks and during quiet passages of track 2 side 1, side 2 very quiet, nice copy ~ $6
Nat King Cole ~ Unforgettable ~ Capitol T 357 Mono 1954 ~ VG very mild shelf wear on back, less on front, top edge is split half way/VG+ some scattered non distracting noise here and there, nice sounding copy for a 60 year old record ~ $6
Commodore's ~ Live (2LP) ~ Motown M9-894A2 (gatefold) ~ VG moderate shelf/ring wear, bent corners, no splits, inner gatefold is nice, one small stain/VG+ scattered very light tics and noise here and there ~ $4
Commodore's ~ Natural High ~ Motown M7-902R1 ~ VG+ some minor shelf/ring wear at bottom front and rear/VG++ some very light tics during Three Times a Lady, scattered barely audible noise elsewhere ~ $3
Rita Coolidge ~ Anytime...Anywhere ~ A&M SP 4616 NM in shrink but opened, lyric inner sleeve is flawless/NM- a few very light tics between some tracks ~ $3
Dr. Hook and the Medicine Show ~ Columbia C 30898 ~ VG+ minor edge wear and shelf wear, lyric insert has 4 small pen marks in corner/VG++ occasional light tics here and there, very nice copy ~ $5
Dr. Hook ~ Revisited (The Best of) ~ Columbia C 34147 ~ VG+ very minor shelf wear mostly on back/VG++ very few light tics here and there, very nice copy ~ $5
Bob Dylan ~ Desire ~ Columbia PC 33893 ~ VG+ ring wear and scuffed edges/VG+ sporadic light noise between some tracks, a few light tics here and there ~ $8
Dan Fogelberg ~ Phoenix ~ Epic FE 35634 ~ VG++ (gatefold) 1" long scuff on binder edge, otherwise perfect/ VG++ sporadic light tics here and there, otherwise very quiet ~ $3
Dan Fogelberg ~ Nether Lands ~ Epic PE 34185 (gatefold) ~ VG++ minor scuffs at binder edge, inner lyric sleeve has 2" split at bottom/VG++ sporadic light tics here and there, otherwise very quiet ~ $3
Grand Funk ~ Live Album (2LP) ~ Capitol SWBB-633 (gatefold) ~ VG moderate wear but no splits, name written on cover, no poster/VG to VG+ scattered non distracting light noise and tics throughout, some loud pops on last track side 1, Heartbreaker and Mean Mistreater ~ $5
Paul Hardcastle ~ 19 ~ Chrysalis 4V9 42875 12" (33 1/3 rpm) single ~ NM- bent corner/NM dead quiet throughout ~ $2
George Harrison ~ The Best of GH ~ Capitol ST-11578 ~ VG++ very light shelf wear on back, insert sleeve is perfect/VG+ very light noise between some tracks, a few tics during a couple of tracks ~ $6
Heart ~ Dreamboat Annie ~ Mushroom MRS-5005 (gatefold) ~ VG+ light shelf wear, inner lyric sleeve has writing and small split at bottom/VG constant light noise on side 1, side 2 is slightly better ~ free with any purchase if you ask for it
Journey ~ Escape ~ Columbia TC 37408 ~ barcode 7464-37408-1 ~ NM- tiny scrape on binder edge (in shrink)/VG++ nearly dead quiet ~ $5
Kansas ~ Monolith ~ Kirshner FZ 36008 ~ NM- (gatefold)/VG+ occasional light noise between tracks and quiet passages ~ $5
Kansas ~ Leftoverture ~ Kirshner PZ 34224 ~ VG++ couple of tiny scuffs on binder edge, hint of ring wear, lyric inner sleeve is flawless/VG+ some light surface noise between tracks and some quiet passages ~ $6
Kansas ~ Point of Know Return ~ Kirshner JZ 34929 ~ VG++ faint hint of ring wear, lyric inner sleeve is flawless./VG++ occasional very light noise between some tracks, a few ticks during Dust in the Wind ~ $5
Kansas ~ Audio Visions ~ Kirshner FZ 36588 ~ barcode 7474-36588-1 ~ (in shrink) 1 inch long scuff on binder edge, lyric inner sleeve is wavy, no splits/NM- couple of light clicks between some tracks and in the quiet intro to last track side 1, this record may have only been played once before I played it ~ $4
Kansas ~ Two for the Show (2LP) ~ Kirshner PZ2 35660 ~ VG++ one tiny scuff on binder edge, very slight ring wear, gatefold and inner sleeves are perfect/VG++ very light noise between tracks, a little noise during last track side 2 ~ $5
Dean Martin ~ Dream With Dean ~ Reprise RS-6123 Stereo 1964 ~ VG+ mild shelf wear on back, less on front/VG+ scattered light pops and clicks throughout, nice copy for a 50 year old record ~ $3
Sting ~ The Dream of the Blue Turtles ~ A&M SP-3750 ~ VG++ slight fraying at opening/NM- very quiet, couple of light pops at the beginning of Russians ~ $5
Barbra Streisand ~ Greatest Hits ~ Columbia PC 9968 (still sealed) $5
Styx ~ The Grand Illusion ~ A&M SP-4637 (RCA record club release) ~ VG+ minor scuffs on binder edge, minimal shelf wear, inner lyric sleeve partially split on 3 sides/VG+ some very light noise between tracks ~ $5
Styx ~ Paradise Theater ~ A&M SP 3719 (gatefold) ~ VG+ some very light edge wear/VG to VG+ surface noise between tracks and during quiet passages ~ $3 or free with purchase of The Grand Ilusiion.
Survivor ~ Eye of the Tiger ~ CBS ZF 38602 ~ barcode 7464-38062-1 ~ (in shrink) small scuff on binder edge, inner lyric sleeve has 2" split/NM- very quiet, a few tics between 2nd and 3rd track side 2 ~ $6
Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • deronb1
    deronb1 Posts: 5,021
    Can i get Harrison,Rita and Dreamboat Annie please?
  • deronb1 wrote: »
    You sure can. PM coming when I get to work today.
    Main System 2.2:
    Home Theater 5.2:
  • maximillian
    maximillian Posts: 2,149
    Could I take:
    Both Boston records
    PM me your address and total and I will send you a MO.
    Thanks.
  • Could I take:
    Both Boston records
    Thanks.
    All yours. PM coming soon.
    Main System 2.2:
    Home Theater 5.2:
  • Kansas ~ Monolith ~ Kirshner FZ 36008 ~ NM- (gatefold)/VG+ occasional light noise between tracks and quiet passages ~ $5
    These two were sold elsewhere.
    Main System 2.2:
    Home Theater 5.2:
  • This one is SOLD also.
    Main System 2.2:
    Home Theater 5.2:
  • This is what is left. Make an offer on any or all of them by PM.
    Main System 2.2:
    Home Theater 5.2:
  • All remaining records are 50% off listed price.
    Main System 2.2:
    Home Theater 5.2:
  • deronb1
    Got the vinyl today Carl. Thanks. Freaked me out a little when i opened the package and the Disney Christmas album was staring me in the face! :)
  • maximillian
    Got mine today also. Had the same reaction when there was a "roaring 20's" cover in there. Thanks!
  • Wardsweb
    Wardsweb Posts: 942
    I will take Nat King Cole, Dean Martin, Styx Grand Illusion w/ Paradise Theater.
  • deronb1 wrote: »
    Thanks guys. Those old empty jackets come in handy as stiffeners to fill up the mailers.
    Main System 2.2:
    Home Theater 5.2:
  • Wardsweb wrote: »
    Thank you. PM coming soon.
    Main System 2.2:
    Home Theater 5.2:
  • maximillian
    edited February 2015
    I've had several others do the same thing. Regardless of how many times I have received records like this, it gives a 2-second "#$#@ he sent me the wrong package" reaction.
    Thanks for caring about details like this. Thanks for quick shipping and great communication. And thanks for the tunes.
  • Thanks guys. Those old empty jackets come in handy as stiffeners to fill up the mailers.
    You are most welcome. Thanks for the positive feedback.
    I almost did send you the wrong record. I had Point of Know Return in your pile instead of Leftoverture. Fortunately, I ran out of shipping tape, so your mailer wasn't completely sealed yet.
    Main System 2.2:
    Home Theater 5.2:
  • Last chance bump. Any unsold records are heading to the local record exchange this weekend.
    Main System 2.2:
    Home Theater 5.2:
  • maingey
    maingey Posts: 632
    do you mind updating the list? I think what I was interested in was just picked up but wanted to make sure.
  • dromunds
    dromunds Posts: 10,123
    Can't believe Dylan's Desire is still there at that price. That's a classic fellas.
  • maingey wrote: »
    Main System 2.2:
    Home Theater 5.2:
  • dromunds wrote: »
    Me too. I figured that would be one of the first to go, even at the original price.
    Main System 2.2:
    Home Theater 5.2:
  • These are all gone. Thanks for looking.
    Main System 2.2:
    Home Theater 5.2:
  • leftwinger57
    leftwinger57 Posts: 2,917
    I like the fact you graded by listening to them. I bought a Stones lp on E-Bay w/ a VG++ rating both the vinyl and sleeve and free shipping. I get the thing and there were so many pops and crackles that it was hard to listen to. Thankfully the seller included a letter w/ contact info and I did. I later found out he only visually grades his albums. What, you don't need to see scratches to have a beat lp. He gave me the choice of either a full refund or since he had other copys I could do that. I wanted the album, it came almost mint and he kept his word so I called to thank him and gave him 5 stars across the board for making good on the deal. Oh the album is Let It Bleed.
  • vc69
    vc69 Posts: 2,500
    Damnit! Missed the Paul Hardcastle. *crying*
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • vc69 wrote: »
    I traded it to my local Record Exchange for store credit. I saw it there the last time I stopped in. They actually had 2 copies. They were asking $8 if I recall correctly. If you're still interested, I can buy it for you and ship it Media Mail for $12.
    Main System 2.2:
    Home Theater 5.2:
