TL upgrade for AB700/800?
nooshinjohn
Does anybody know what moves I need to make on the crossover to accomplish this? I know I could drop in the RDO-194's, but would like to run the same tweeters that I have in the 1.2TLs.
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18804.pdf
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18805.pdf
John...excuse my ignorance but what are the AB700 and 800 and where can I get more information? Thanks!
These are among the first generation of high-end Polk in-wall speakers. They run the same drivers as the SDA-SRS. In this case they use the SL2000 tweets and MW6512 driver.
The 700 has one driver/tweeter and the 800 has two drivers and a single tweeter.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
John, The RTA-8T has an almost identical Hi-Pass section. There's an RTA8TL-Rev2 Schematic, for use with the RDO-198s. Looks doable, if you can fit everything on the circuit board.Home Theater/2 Channel:
dhsspeakerservice.com/
