Will I have too much bass?
crx_si_1990
crx_si_1990 Posts: 7
edited August 2004 in Car Audio & Electronics
I'm going to start off by listing all of the equipment I have that's waiting to be installed.
Headunit: Alpine CDA-7995
Speakers: Polk MOMO MM6 (two sets)
Subwoofers: Polk MOMO MM124 (x2)
Amplifiers: JBL Px300.4 (75Wx4 RMS)
JBL BPx1100.1 (1100Wx1 RMS @ 2OHMS)
Power and ground wire by Monster Cable
Interconnects by Tsunami
My question is this: Having only 75 watts per channel to the speakers, are the subs going to be loud enough that my mids and highs won't be able to keep up? I think it'll be fine, but I wanted some other opinions.
Nick
Post edited by crx_si_1990 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2004
    i think you'll be good; it's a lot a matter of personal taste, but w/ 2 mm6 sets, have at...
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2004
    Agreed.
    You can always tune your gains til you get the right mix. Once youve set the mid/high gains properly simply adjust the bass gain til it blends properly with the rest and youll be fine.
  • neomagus00
    edited July 2004
    i concur with mac's gains-setting idea, with one modification - set both gains to proper levels, then lower the offending one... this ensures that, in the event your mids & highs are louder than your subs, you don't push the sub amp into clipping...
  • MacLeod
    edited July 2004
    Ah, yes. I didnt think of that. That is a good point tho and is cheap insurance against blowing a hole in your sub. ;)
  • MTXMAN
    MTXMAN Posts: 682
    edited August 2004
    i say no, mainly by virtue of the fact that i view it as impossible to have too much bass....
    Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax.
  • crx_si_1990
    edited August 2004
    I figured it'd be ok because it really doesn't take all that much power to produce good mids and highs. 75 watts per corner should be alright.
    I won't really have to worry about driving either of the amps into clipping, both of them have a status LED that lets you know if it's clipping. That way when i go to adjust the gains i can turn them until the amps are slightly clipping and back them off a bit.
  • MacLeod
    edited August 2004
    Well, you could use a little more power than 75 watts. The MM6 really likes power and the more you use up to 150 will make it sound better.
    If it were me, I would do without rear speakers and bi-amp the front MM6s with the 4 channel. The MM6 x-over isnt set up for it but I would run the front channels thru the x-over and to the tweets and the rear channels straight to the mid. I think this would yield the best SQ.
    But since you have already shelled out the scratch for the 2nd pair of Momos, this probably isnt a practical suggestion. :D
  • crx_si_1990
    edited August 2004
    I would but I like having the rear fill, not quite sure why but to me it just doesn't seem quite right without it.
  • MacLeod
    edited August 2004
    Hey bro, if thats what you like then good on ya!
    End the end, thats all that really matters; what you think sounds best. ;)
  • crx_si_1990
    edited August 2004
    I've done some reading and I think I'm going to try both configurations and let my ears decide. I think I'm leaning toward Bi-amping them simply because it'll double the power to the front of the car and sound alot better.
    Nick
  • MacLeod
    edited August 2004
    Thats my vote!
    Agein, it will sound better but mainly because of the hellacious flexibility in tuning the tweeters output as opposed to using the x-over's.
    I doubt Ill ever run straight 2 channels again.
  • MTXMAN
    MTXMAN Posts: 682
    edited August 2004
    yeah, I know i'm kinda wishing i'd gotten the 75x4 us tube amp instead of the 150x2... maybe i'll get that too and find some of those (fairly rare) 6.5" quasi-subs... i think focal makes some and so do some others... rainbow used to but they stoped.... run those off of the tu-600 and put the mm6's on the tu4360....
  • exalted512
    exalted512 Posts: 10,734
    edited August 2004
    i heard focals 6" subs in a corvette
    shocked the crap out of me that they can sound so deep
    def. not a bad choice
    -Cody
  • MacLeod
    edited August 2004
    Morel makes a 5" sub and a 6.5"
    Bargain prices too!
    The 5's MSRP is only $550 with the 6 going for a paltry $650!
    I wish I could hear some Morels somewhere. I keep reading about them and they are supposed to be super smooth!
  • MTXMAN
    MTXMAN Posts: 682
    edited August 2004
    650 each? hmm that's a little outa my price range for that...
    *edit*
    just saw that Digital Designs makes a 6.5" midwoofer... need to find out what the freq response is on the long throw version of that... it's only 129 each and they're supposed to be a pretty good company....
  • exalted512
    edited August 2004
    DD is a very good company
    the 9915 is one helluva sub
    -Cody
