are heavier weighted LPs better ?
leftwinger57
I just got my brand new copy of Gram Parson's Grievous Angel and besides the obvious weight in just handling the record is there any sonic difference w/ differing gram weighted albums ? Again this is brand new LP and needed a razor to open the thing so I have nothing to compare it to. Some forums said it was the pressing plants decision for the weight and anything over 130 grams would be enough to meet production standards.
If you are talking about sound quality. No. The 180 gram records is nothing special. I have British pressings that are wafer thin and sound great and 180 gram records that sound like c-r-a-p. Heavier records may be bit more durable and are definitely less prone to warping, but it really comes down to the mastering and the sound production.Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded -
Yes, builds up strength and hand eye coordination.
I threw my back out trying to get one on the platter last week.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
a priori, no. The current fad of heavy vinyl, I think, is driven by:
* Nostalgia (in the early days of LPs - i.e., the 1950s - they were thick and heavy).
* Reaction against the horrid RCA "Dynaflex" records of the early 1970s and the arguably even more horrid late-1970s "energy crisis" records pressed on recycled vinyl.
* The commonly held hifi perception that "heavier is better" (or its corollary, "quality is proportional to weight").
As said above, some of the modern heavy pressings are good, some are not. You pays your money, you takes your chance ;- )
I don't know if they sound better ( I doubt it). I know I like when I get a 180g because it feels better in my hands and feels durable. I notice they arent as warped as the thinner stuff.
B&W CM9Classé Sigma -
They cut the grooves the same on a 130g to a 200g.Anaheim Hills CA,
