TUBE ON A CHIP
F1nut
F1nut Posts: 51,967
This is extremely exciting news, a game changer if there ever was one.
http://www.korg.com/us/news/2015/012212/
    nooshinjohn Posts: 25,991
    Still a long way to go before these will make an I-pod sound even close to mediocre, much less good. Great to see tube tech making another leap forward though.
  • headrott
    headrott Posts: 5,496
    That is an interesting idea. I would absolutely have to hear it before believing it sounds as "rich" and has the great harmonics of a "true tube" though. I am not saying it doesn't, but will believe it when I hear it is all I'm saying. :)
    The anode, cathode, filiament, and grid must have a compromise to be as small as it looks. Perhaps I am mistaken though; I can't wait to hear one!
    Thanks for posting Jesse!
  • dromunds
    dromunds Posts: 10,137
    "easy to power on batteries" also sounds appealing.
    about time hardware starts taking a leap forward. Love the idea, not so sure about attaching to circuit boards though. It may use less energy, but what about any heat issues being so close to the circuit boards ?
    Won't make it any easier to tube roll either it looks like.
    mhardy6647 Posts: 35,216
    edited February 2015
    http://www.audiokarma.org/forums/showthread.php?t=639767&highlight=korg
    Not really what I'd consider a 'tube on a chip' (although there have been some cold-cathode "solid state vacuum tubes" proposed and/or prototyped before); the Nutube :-P is a purpose-built version of a VFD (vacuum fluorescent display) to work as a small-signal triode. Folks in the DIY/hobbyist community have "repurposed" regular old VFDs as triode amplifier tubes with (well, frankly) mediocre results. One of the local New England vacuum tube hifi gurus played around with 'em a bit and moved on.
    http://hackaday.com/2013/11/09/vfd-display-becomes-an-amplifier/
    http://www.eham.net/articles/20809+
    http://www.qsl.net/m0ayf/VFD-Regen.html
    https://threeneurons.wordpress.com/vfd-stuff/
    BUT, of course, a "VFD" style device that has been deliberately designed to function as a triode (presumably using low plate voltage) is much more likely to be linear enough for "hifi" -- but the intended application looks to be for MI/PA amplifiers and effects, given the source; so it may not be a device intended for low-distortion applications.
    Might have some application in hifi, but we'll have to see.
    EDIT: This, I think is the basic idea of the monolithic cold cathode triode I mentioned above: http://ieeexplore.ieee.org/xpl/articleDetails.jsp?reload=true&arnumber=1019936
  • skrol
    skrol Posts: 3,460
    Stan
    Main 2ch:
    HT:
    Other stuff:
