TUBE ON A CHIP
F1nut
in Electronics
This is extremely exciting news, a game changer if there ever was one.
http://www.korg.com/us/news/2015/012212/
Still a long way to go before these will make an I-pod sound even close to mediocre, much less good. Great to see tube tech making another leap forward though.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That is an interesting idea. I would absolutely have to hear it before believing it sounds as "rich" and has the great harmonics of a "true tube" though. I am not saying it doesn't, but will believe it when I hear it is all I'm saying.
The anode, cathode, filiament, and grid must have a compromise to be as small as it looks. Perhaps I am mistaken though; I can't wait to hear one!
Thanks for posting Jesse!
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
"easy to power on batteries" also sounds appealing.
about time hardware starts taking a leap forward. Love the idea, not so sure about attaching to circuit boards though. It may use less energy, but what about any heat issues being so close to the circuit boards ?
Won't make it any easier to tube roll either it looks like.HT SYSTEM-
lsi 9's -
http://www.audiokarma.org/forums/showthread.php?t=639767&highlight=korg
Not really what I'd consider a 'tube on a chip' (although there have been some cold-cathode "solid state vacuum tubes" proposed and/or prototyped before); the Nutube :-P is a purpose-built version of a VFD (vacuum fluorescent display) to work as a small-signal triode. Folks in the DIY/hobbyist community have "repurposed" regular old VFDs as triode amplifier tubes with (well, frankly) mediocre results. One of the local New England vacuum tube hifi gurus played around with 'em a bit and moved on.
http://hackaday.com/2013/11/09/vfd-display-becomes-an-amplifier/
http://www.eham.net/articles/20809+
http://www.qsl.net/m0ayf/VFD-Regen.html
https://threeneurons.wordpress.com/vfd-stuff/
BUT, of course, a "VFD" style device that has been deliberately designed to function as a triode (presumably using low plate voltage) is much more likely to be linear enough for "hifi" -- but the intended application looks to be for MI/PA amplifiers and effects, given the source; so it may not be a device intended for low-distortion applications.
Might have some application in hifi, but we'll have to see.
EDIT: This, I think is the basic idea of the monolithic cold cathode triode I mentioned above: http://ieeexplore.ieee.org/xpl/articleDetails.jsp?reload=true&arnumber=1019936 -
Vacuum Transistor
http://www.extremetech.com/extreme/185027-the-vacuum-tube-strikes-back-nasas-tiny-460ghz-vacuum-transistor-that-could-one-day-replace-silicon-fets
Stan
Main 2ch:
HT:
Other stuff:
