Capacitor and resistor question
machone
Does it matter which way Sonicaps capacitors and Mills resistors are installed? I see no indication of polarity.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Best Answer
John, your answer is a little confusing, so to be clear.....Does it matter which way Sonicaps capacitors and Mills resistors are installed?
No.Political Correctness'.........defined
Answers
As far as I know the caps do have a polarity and should have some indication...There is no polarity for the Gen 1s, but the Teflon caps use the long lead to the source or input & the short lead to the load or speaker. (last part of my statement lifted from web source)The resistors are good to go regardless of orientation. I would just make sure that you do each board exactly the same.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks guysMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Jay
