Capacitor and resistor question
Does it matter which way Sonicaps capacitors and Mills resistors are installed? I see no indication of polarity.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Best Answer
    F1nut Posts: 52,008
    Answer ✓
    John, your answer is a little confusing, so to be clear.....
    No.
Answers
    nooshinjohn Posts: 26,002
    edited February 2015
    As far as I know the caps do have a polarity and should have some indication...There is no polarity for the Gen 1s, but the Teflon caps use the long lead to the source or input & the short lead to the load or speaker. (last part of my statement lifted from web source)The resistors are good to go regardless of orientation. I would just make sure that you do each board exactly the same.
  • machone
    machone Posts: 1,566
    Thanks guys
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • agfrost
    agfrost Posts: 2,474
    No.
    Can't get any more clear than that!
    Jay
