Please Help with replacement Driver.
warlocks1
warlocks1 Posts: 1,284
edited April 2002 in Technical/Setup
I just received my MW6510 driver from Polk for my RTA-11t's. The old one would botom out at moderate levels. I installed the new driver and matched the white and black cables. Now I only get sound from the tweeter. I reinstalled my old driver and everything is great (except the bottoming out problem). What's the deal? Did I get a bad driver and would that cause the problem in the other driver's sound level? Should I try reversing the wires? Thanks, Jeff
Post edited by warlocks1 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2002
    Even with polarity reversed, you will still get sound from a functional driver.
    Hook the raw driver up to the speaker wire from your amp (free air), AT A VERY LOW LEVEL, and you should hear something....if you don't, call cs and send it back.....
    Cheers,
    Russ
  • warlocks1
    edited April 2002
    Wow, that was fast! Thanks Russ. I will give it a try.
  • warlocks1
    edited April 2002
    I just tried and I get no sound whatsoever. I will call them tomorrow. I know it won't be a hassle, that's why I love Polk Audio. Again, thanks for the help!
  • axeman
    axeman Posts: 170
    edited April 2002
    Sounds like you just got a lemon.......................a real rarity for Polk, but rest assured they will make it right.
    That is why they are GREAT!!!!
    Peace,
    Joe
