What size amp wiring
What size amp wiring for install of Pioneer 900 Watt 4ch amp
Answers
  • Speaker cables or AC power cables?
    How long are the runs?
    ....and if speaker cables, what's it going to be connected to ?
  • Sorry, I wasn't clear... Actually both power and speakers. install is in dodge Dakota extended cab so runs are 5-6 feet max. does that help?
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited February 2015
    4AWG Copper, not copper clad/coated aluminum, and 14-12AWG(again, not CCA) wires. Get some decent IC's too hook up tour amp to your pre outs. What sub are you running?
  • speakers are polk DB6501 component set (100 Watts each side RMS) (Front)
    and DB651's (80 watts RMS) (rear) 4 spkrs total. head unit is alpine cda-95xx series amp iis going to be Polk audio pa660. 4 channel, 75 watts rms
  • Use the best wires you can get, avoid brands like Pyle and boss, knu koncepts makes decent stuff, as does kicker, if you sent something you're considering, run it by the folks here, and they'll let you know what their experience and tinkering has taught them.
  • Thanks, That info will definitely help...
  • Speedskater
    Speedskater Posts: 495
    4AWG Copper, not copper clad/coated aluminum, and 14-12AWG(again, not CCA) wires. ..................
    We see more of this copper clad/coated aluminum wire in big-box stores and on-line stores. Often with major brand labels like 'RCA'.
    But 4 AWG?
  • For the power cord to the amp. Thought he would be running a sub as well, 8should do fine there.
