What size amp wiring
BryanE
Answers
Speaker cables or AC power cables?
How long are the runs? -
....and if speaker cables, what's it going to be connected to ?HT SYSTEM-
lsi 9's -
Sorry, I wasn't clear... Actually both power and speakers. install is in dodge Dakota extended cab so runs are 5-6 feet max. does that help?
4AWG Copper, not copper clad/coated aluminum, and 14-12AWG(again, not CCA) wires. Get some decent IC's too hook up tour amp to your pre outs. What sub are you running?2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
speakers are polk DB6501 component set (100 Watts each side RMS) (Front)
and DB651's (80 watts RMS) (rear) 4 spkrs total. head unit is alpine cda-95xx series amp iis going to be Polk audio pa660. 4 channel, 75 watts rms -
no sub, no room
Use the best wires you can get, avoid brands like Pyle and boss, knu koncepts makes decent stuff, as does kicker, if you sent something you're considering, run it by the folks here, and they'll let you know what their experience and tinkering has taught them.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
Thanks, That info will definitely help...
We see more of this copper clad/coated aluminum wire in big-box stores and on-line stores. Often with major brand labels like 'RCA'.seabeerob213 wrote: »4AWG Copper, not copper clad/coated aluminum, and 14-12AWG(again, not CCA) wires. ..................
But 4 AWG?
For the power cord to the amp. Thought he would be running a sub as well, 8should do fine there.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
