FS: Set of 4 Brand New (unused) Polk MW6510 replacement drivers
FS: Set of 4 Brand New (unused) Polk MW6510 replacement drivers for use in vintage Polk Audio speakers.
I found these in my audio closet and, since I have no need for them as I no longer own any vintage Polk Audio items, I’m letting them go here for $85 + shipping.
I have the original box so they will be securely packaged for the journey to your home.
Local pick, of course, is available and encouraged.
Thanks.
Oh, BTW, when installing these replacement drivers, you should trim the rubber around the openings for the screws. If you don’t and you just screw them in as-is, you might tear the rubber as the screw gets tighter. Use a very sharp blade and use caution.
