My First Crossover Rebuild
trav0810
I recently acquired a pair of monitor 5a parts (including cabinet). I have decided that since they are already in pieces, this would be a good time to get my feet wet. And this looks to be about as simple of a crossover as I could hope for.
2 caps, 2 resistors on each speaker. Due to an extremely limited budget, I will not be going TOTL on this at all. I will probably go with Jantzen or Erse. But first, I'm off to buy a fire extinguisher.
The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
Thorens TD320
Modified Carver C-1
Hey Travis
I did my Monitor 4's myself, I used some caps that were pretty big had a little trouble getting them inside, I ended up mounting the bigger caps on the inside but not back on the binding post. the only thing that got burnt was my finger
Dave help me find a better binding post cup that fit without making the hole bigger for my 4's.
Have fun with it.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
When I did my 5's I was concerned about the new caps fitting on the board. Dave (westmassguy) suggested mounting the resistors on the bottom of the board so there would be room for the caps. It worked great.
That was a great idea. Thanks for passing it on. I might end up doing the sameThe difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
White Lightning Moonshine DIY Speaker Cables and Interconnects -
I have started gathering up some tools.
Thorens TD320
Modified Carver C-1
Now, can I get some recommendations on what solder to buy?The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Cardas Quad Eutectic. Best stuff on earthHome Theater/2 Channel:
dhsspeakerservice.com/ -
Yup I bought some for my sub build and will be using it next weekend!westmassguy wrote: »Cardas Quad Eutectic. Best stuff on earth
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
That stuff isn't cheap!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
RadioShack sells solder too if you just gotta have it today lol..
I'm ordering it...besides...RadioShak is closed on Sunday in New Tucky!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
You can by it by the foot, don't have to buy the rollHome Theater/2 Channel:
Yes you do. You have to buy it by the roll because once you use it, you will never use anything else.
Agreed, but it is expensive, especially for a single project.
I buy it by the roll because I use so much of itHome Theater/2 Channel:
Well, this is my first project, but if I don't burn the house down, it shouldn't be my last. A good friend of mine on the forum here is sending me some of the Cardas to try out. I had ordered some old Kester 44 on the recommendation of a few other guys I know. It will be cool to compare the two.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Cardas rules. I think you'll be convinced once you try it.Home Theater/2 Channel:
Satisfy my curiosity please? Why? I'm always up for "bang for the buck" items such as these. I think bought my last roll from PE.westmassguy wrote: »...Best stuff on earth
Thnx, tony
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Eutectic Solder is a blend of different metals. The combination has a lower melting point than conventional solder, so less heat required, less burned flux, safer for components. As ZLTFUL said, it was formulated exclusively for high-end audio circuitsHome Theater/2 Channel:
I LIKE the "...blend of different metals... ...lower melting point than conventional solder, so less heat required" stuff. I've made & repaired dozens of Pro patch & mic cords in addition to (some) home wishing for just such a product!!
Mille Grazie! [a thousand thank you(s)] for the tip.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Years ago, I worked for Eutectic-Castolin in Flushing, NY. Those people are SERIOUS about their welding and soldering!TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
not really low price... that is basically a tad more that 15 feet from overseas for $9. Here from Sonic Craft, you get 24 feet for the same price. And right now it is on sale for even less.
http://www.soniccraft.com/index.php/solder-lead-c-157_150_385
Quick question ... I usually buy the lead free Cardas TE... is it better to have the lead in the Quad?
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Cardas Eutectic, nothing else comes close.is it better to have the lead in the Quad?
IMO, yes. Look a little lead isn't going to hurt an adult. Now, if you solder with it all day, every day I can understand having a concern.
President of Club Polk -
I use it everyday, that would explain a lotHome Theater/2 Channel:
Is this...
...the stuff I want to buy? I want to jump on it while on sale. I'm about to make some custom length ICs & anticipate more speaker stuff. Further, this is more than I've used in several years.Cardas Eutectic, nothing else comes close.
Thx, Tony
