Crossover upgrades and new tweeters
So if it's Mylar, does it not lose capacitance and therefore does not need replacement?
You replace it because film and foil caps are superior.Political Correctness'.........defined
President of Club Polk -
Be sure replace the resistors while you're in there with Mills.Political Correctness'.........defined
Just ordered my 4 new rdo194 tweets, yee haa! I will be on the porch like a hound waiting on the UPS truck.
Done!! The crossover upgrades are complete; including the TL mod and new RD0198 tweeters. A little change from the norm, I mounted the paired 20uf sonicaps for the sda drivers to the floor of the compartment and connected them with chassis wire. This gave me plenty of room on the board for the other caps. The depth and clarity is off the charts, and the highs are tight and clear. Awesome! My beloved Polks' are back...Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Now you need some serious burn in time ...after 200 hours my 10's were a whole new beast! they well just keep getting better for awhile. ENJOY!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Cool. When I upgraded my 2B's they sounded great from moment I started playing them. I didn't notice any degradation in sound and then an improvement in sound (over the course of a couple of years) as others have experienced. YmmvSDA SRS 2.3TL's
SDA 2B TL's -
Congrats Randy. I am waiting for parts to arrive for my 2As. Hope I have similar good news
I, too, had no capacitor "burn in" issues.michaeljhsda2 wrote: »Cool. When I upgraded my 2B's they sounded great from moment I started playing them. I didn't notice any degradation in sound and then an improvement in sound (over the course of a couple of years) as others have experienced. Ymmv
My speakers were better from the first note.
My crossover upgrade sounded great right from the start. I didn't experience any ups or downs in performance over time like some have reported.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
which caps did you go with? -
Dayton film caps for the 20uf parts. A friend is sending me the 130s, so I'm not sure if they are Mylar or electrolytic. Soon come, mon. My setup is different than yours.
Did you jump your polyswitch? That is what I plan to do. Still waiting for my parts...
I have not done my crossovers yet, saving the funds. Almost have everything else completed. That's why I wondered what kind you used. and how they sound to you. -
Of course, when upgrading from the stock caps/resistors the sound will be better right away, that's a given. However, the sound will continue to improve for the first couple of hundred hours (Sonicap and Clarity) until they are fully cooked. Aspects that improve over that span are tighter bass, smoother highs and a fuller midrange. Basically, a better overall balance than at the beginning. I've heard this each and every time, so it's hard for me to understand why some of you haven't.
Furthermore, I can't say I've heard Sonicap or Clarity caps go back and forth, it's more of a steady improvement. However, I can say that Mundorf caps do go back and forth, they also take at least 300 hours to fully cook.Political Correctness'.........defined
Unsurprisingly, not everyone agrees with Crites. I did not hear changes--good or bad--that I can put down to "break-in" when I replaced the caps in my 1Bs. They just sounded great, instantly, and still do.
http://www.critesspeakers.com/frequently-asked-questions.html
Q: Do components have a break-in time?
A: Some do and some don't. Capacitors would be a definite NO. Let's look at this one a bit.
You have new good quality capacitors installed in your crossovers. Capacitors have exactly two qualities that effect the sound of your music that goes through them. Those are capacitance (what we use them for) and ESR. ESR is the sum of all other qualities of a capacitor other than capacitance expressed as an Equivalent Series Resistance. ESR is a bad thing. Good caps have ESR so low it is barely measurable, on the order of a couple of hundredths of an ohm. ESR is made up of stuff like the resistance of the leads and their connections to the foil inside the capacitor or stray inductance or dielectric absorption.
So, we put our new caps in the crossovers. These new caps are right on the capacitance value the design calls for and the ESR is almost unmeasurably low. What exactly of these two qualities do you expect to change with break-in? And if either of them changed, why would you expect the sound to get better since the only way they could change is to go away from the "perfect" values they had to start with? I hope any caps you use in your crossovers are good enough that they do not change at all for many years of use.
http://www.audiokarma.org/forums/showthread.php?t=637954
I've read the Crites stuff before and I'm convinced the guy's hearing is completely shot. He ignores the fact that different brands use different materials and different methods of construction, all of which have a large impact on the way a given cap sounds. He also ignores the fact that the material needs to form through charging and discharging, which is not all that unlike the need to bring up a long unused piece of gear on a Variac to allow the caps to form properly. In addition, the shear number of people who report the same basic results is so overwhelming that to dismiss or dispute cap burn in is foolish at best.
I have experienced what F1 touts. Mine sounded somewhat better from the start but over time the the presence and clarity has increased. On the 1C the 200 hours burn was an extended time due to fact they were used infrequently compared to the 2.3 TLS everyday use.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I have also experienced the improvements during the break in period. My experience with Sonicaps has been that the big improvement comes between 50-100 hours, and I have definitely witnessed the fluctuations in between. They progress, then regress, then improve again. After 100 hours, the improvement was more subtle and sustained (no more fluctuations), and after 200 hours they are primo.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
When I first got my crossovers back from Dave I thought they sound a lot better from the start, then I started a burn in program of 12+ hours a day and after 100 I listen again and the thing that changed the most was the high's but they were new RDO-198 tweeters so maybe they were burning in too. then I listen again after 200+ etc...
To me I plainly heard improvements along they way, now I did have some fairly new analog cables that sort of got burned in also.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
He completely misses dielectric absorption, also known as "capacitor memory". Charge up a capacitor then completely short it out. In a perfect world the capacitor would remain uncharged, but that doesn't happen. There will be a "ghost" of the original charge coming from the dielectric material storing the charge. In audio this effect robs transient clarity and masks detail and "pinches" the sound, especially noticeable in instruments that produce a great deal of higher frequency overtones, such as brass and stringed instruments.
If you ever find yourself internally wincing when you're listening to certain music being played on a sound system that could be the cause.
finished my SDA2A refurbish last night. New RDO194 tweeters, new capacitors, jumped the polyswitch. Did not touch the resistors, as I assume they don't deteriorate. The speakers were in good shape before I started, so difference is subtle. Better clarity and definition in the high end. Tried the tweeters before re-capping and they sounded duller than the SL2000s, but back to quality with new caps installed. The soundstage is more expansive and seems wider than before. so far so good. only have listened briefly.
BTW, I have not seen anything posted about adding some kind of sound dampening fiber material to the cabinets. Is that recommended? Mine are stuffed in the upper section, but the bottom has nothing. Has anyone found this to be helpful?
My 2A journey:
http://forum.polkaudio.com/discussion/143984/my-2as-finally-finished-almost/p1
The bottom of the cabinet should be completely empty. The Dacron should be no lower than the top of the PR opening, or the bottom of the lowest woofer opening.Home Theater/2 Channel:
dhsspeakerservice.com/ -
ZLTFUL: Interesting that you think that. I spoke with a Polk tech advisor who says it would make no difference to change the resistors. But if I was to do that, I don't see 2.7ohm 10% 5W resistors online anyway. And thanks westmassguy for the fiber fill answer. it seemed odd that the cabinets were so starkly empty.
The suggested Mills parts are significantly better at dissipating that thermal load with much lower chances of failure.
And more importantly, the lower inductance of the Mills resistors.I spoke with a Polk tech advisor who says it would make no difference to change the resistors.
Did you ask this person if they have ever modified a crossover? If they have ever used something other than a sand cast resistor?Political Correctness'.........defined
Considering the caps were 30+ years old and way past their expiration date I'm not sure why you think they were in good shape. Furthermore, if the improvement was only subtle that may be a result of using low quality Dayton caps and/or something is amiss in there.Political Correctness'.........defined
F1 next time you are in Denver stop by and give a listen. I'm sure you will have lots of good ideas. ZLTFL I did not see the correct Mills resistors in my search. I'll look again. I did not grill the Polk tech, but on 2 different calls to them I got the same advice. I really have no other SDAs to compare to, but these sound darned good. I bought them from a guy who had them in a box, purchased here in Denver, and they looked like they did not get much use which is amazing for a 1986 item. My other speakers are from the same era, which I purchased in Miami; Energy pro22. They were awesome but the tweeters dried out and died every few years. I gave up on paying for rebuilds as they are no longer available. At the time I purchased them it was either the Energys or the Polk SDAs, so I got em both now.
Thanks for the invite, who knows. As for good ideas, I've peppered this forum with them, might be some bad ones too....LOLI did not grill the Polk tech, but on 2 different calls to them I got the same advice.
Bad advice times 2, I'm afraid.
Your search for Mills is over, http://www.soniccraft.com/
The Polk adviser told me the wrong placement of the 6511's and the 6510's when I asked. And yeah I remember his name...
