My left sda-2 sounds blown
My left sda-2 makes a farting type rumble or pop vibration when the bass hits during high volume (not even close to max). It sounds terrible and I don't know one of the speakers is blown or why it makes that uncomfortable sound.
It's only the left speaker
can I replace the woofer or drivers? Is that the problem?
    F1nut Posts: 51,702
    Need more info. What are you driving them with and what is not even close to max? How long have you owned them? Remove the grill, put your ear up to each driver and the PR (it's not a woofer) to determine which is the problem. Report back.
  • halo71
    halo71 Posts: 4,630
    edited January 2015
    Have you checked that all the screws are tight on the drivers and passive? Have you gently pushed on each midwoofer to make sure there is no scratchy feeling or sound?
    --Gary--
  • I've used all sorts of receivers to drive them. The its like all the speakers in the left tower are maxxed out but the right can handle more.
    F1nut Posts: 51,702
    You are not helping us to help you.
  • boston1450
    boston1450 Posts: 7,758
    :::::: This Again::::::
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • jvc r-s77 4/10 on volume
  • It only happens at high volume so I'd rather not have my ear next to it.
  • realistic sta-2280 _-around the same volume output
  • Kenwood kr-77- around 4.8/10 on the volume
    Sony STR-6036 ^ around the same volume as above
  • I've owned them for about 7 months. always this way.
    nooshinjohn Posts: 25,891
    Sounds like you are over-driving the receivers. SDA can present a tough load for low powered gear like that Kenwood. None of those receivers actually, appear to be well suited for driving these speakers IMHO.
  • boston1450
    edited January 2015
    if this is the receiver @ high volumes that may be the issue. Clipping out on ya. http://www.hifiengine.com/manual_library/jvc/r-s77.shtml
    Randy-Maine
    by David WMG
  • boston1450
    Get yourself a decent amp & preamp around 200wpc or more. More quality power for those wonderful speakers of yours....Think of it this way. You can haul a camper trailer with a half ton v8 truck--right--you hook up to a Ranger v6. Will it do it ? Maybe & its gonna be hard on the v6. Would the v8 do it easier & more efficient? I think so
    Randy-Maine
    by David WMG
  • halo71
    halo71 Posts: 4,630
    Guys, yeah he needs more power no doubt. But if they have been doing that since he bought them. I am thinking the receivers are not the problem here. Unless he clipped the SDA's from the get go. So there are greater issue(s) at hand to deal with.
    I'm gonna say a bad/scratchy midwoofer(s).
    --Gary--
  • boston1450
    edited January 2015
    ^^^^ agree.. I see what your saying. Left speaker. Might be a reason Jesse said more info.. He stated at high volumes with only 60wpc & SDA's ?
    Randy-Maine
    by David WMG
    F1nut Posts: 51,702
    Ok, not only low powered consumer grade receivers, but those speakers are 4 ohm nominal and dip lower. Without checking I'd say none of those receivers are rated to drive a 4 ohm loads. I also have to say 7 months is a long time to live with a busted speaker.
    Since you, the OP, are not willing to get your ears close to the speaker, do you think you could manage to swap one driver at a time with the right speaker in an effort to determine which is the problem?
  • Ok. Clearly I'm out of my league when it comes to powering these puppies.
    The best amp I have, as far as power goes, is a Pioneer SA-1050 which is 100xwpc
    It's definitely the speakers and not the amp cause it's strictly the left.
    Swapping out the midwoofers is a genius idea.
    I'll try that Sunday.
    If it's that can they be replaced?
  • Clipping out? The receiver has never stopped if that's what clipping out is.
    I know the Sony is 4 ohms
    Not sure about the rest.
    But I'm sure they are not powerful enough to really drive these to the highest potential.
    I'm an absolute novice that collects from second hand stores, flea markets and yard sales.
    Maybe I'll find a nice giant Sansui or Marantz one day for a good price or even a McIntosh...
    F1nut Posts: 51,702
    That Sony is the second worst of the bunch. The Pioneer integrated is the best and I'm pretty sure is 4 ohm rated.
    Yes.
    No, clipping happens when the power supply runs out of gas resulting in a clipped signal being sent to the speakers. The sound becomes shrill and compressed. Clipping usually takes out the tweeter(s) first, but not always. General rule of thumb, never go beyond halfway on the volume control, but that will depend on a number of factors. You could easily be in the clipping range with the power gear and speakers you are using.
    Forget the vintage consumer grade receivers, sell all that stuff and get a real piece of audio gear. There are plenty of excellent integrated amps available. You need something with a high current rating.
  • westmassguy
    westmassguy Posts: 6,850
    In addition to what's already been said, you should check the individual woofers for binding or odd noises. Gently press in on the cones. They should move freely, with no rubbing, binding or grating noise. Also, do a air leakage test on the speaker. Press in and hold the Passive Radiator. The woofers should pop out, and stay out for a few seconds, then slowly return to their original position. If they move back immediately, you've got air leaks. Check all the rubber surrounds on the Woofers and the Passive Radiator for cracks, splits or holes.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • This is an interesting thread I had this same issue with a pair of sda srs2's I was driving them with a Carve m4.0t at 375 into 8 ohm 550 into 4 never did figure out why the left speaker farted like that. Can tell you this once they **** that driver is done. I replaced the drivers with silver flutes recomended to me by Helen due to the 6510's being unavailable at rhe time and the problem was cured. A friend of mine had the same setup same issue he sold his pair off.
    silver flutes?
