Pioneer SX680 - 4ohm speaker ?
Would the little sx680 push a pair of OHM e2 small 2 way speakers ok. Not looking for a big sound. Lite listening. I did a little research & figured id ask your opinions. TIA
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • boston1450
    boston1450 Posts: 7,758
    Gonna hook'r up later on after work n give'r a listen :smile: 5 buck speakers didnt break the bank. Thanks
    Randy-Maine
    by David WMG
    Sure she will. Don't let the lower watts per channel numbers fool you. Those old vintage receivers had some pretty beefy power supplies.
  • steveinaz
    steveinaz Posts: 19,546
    I have a minty SX-780 in my shop driving my Energy towers.
  • tratliff
    tratliff Posts: 1,811
    I had a sx-1250 pushing my SDA's for a small time. It did fine until I pushed the volume. It couldn't supply the needed low end but at low to normal listening seemed to run fine. Never got hot but I could push it into protection mode pretty easily when I started rotating that volume knob. The Pioneer was all original and never had any work or upgrades. I think you will be fine since you stated "lite listening".
  • boston1450
    Just hooked them up & very nice little speaker. Tweets stand out nicely IMO. Didnt play with the button on back yet. k5m5ohlrdy42.jpg
    Not the best OHM ive heard but perfect for a small listening area. The little sx seems to push them nicely
    Randy-Maine
    by David WMG
