PSW111 Hookup
drpgeotrv
I have a PSW111 and a Onkyo TXSR607 I have plugged the cable into the "R LFE IN" port and to what port do I plug in the other end?
Thanks,
Don
Thanks,
Don
Are you talking about which port on the back of your Onkyo? since there are 2 preouts for?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
yes on the back of the Onkyo
you could run 2 cables or just use a adapter like this on:
http://www.amazon.com/Mediabridge-ULTRA-Series-Y-Adapter-Inches/dp/B004EBX5GW/ref=sr_1_6?ie=UTF8&qid=1421611439&sr=8-6&keywords=rca+adaptor2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
The PSW111 failed and Polk sent a New board. In the process of installing the new board, I pulled the cable loose. There is no info that I could find on the Polk website that instructs on where to plug in the other end of the "R LFE IN" cable.
Don -
BTW Welcome to the forum. since the back of the Onyko has both a L & R preout for the sub the adapter will send both signals to the sub you you can use LFE (right) but you could use 2 cables since your sub has 2 input L&R also. my AVR just has the one sub out.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thank You
