Panamax M8-AV-PRO Home Theater Power Management
Is anyone familiar with this item?
    Seems like a standard unit well enough for basic protection.
  • Mikey081057
    Mikey081057 Posts: 7,127
    8 outlets enough?
    Garage | Polk Monitor 5B's
  • shawn474
    shawn474 Posts: 3,052
    I have it; what's the question? In use now and as tony said pretty standard unit
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • afterburnt
    afterburnt Posts: 7,892
    8 is not enough, right now the 4 on the amp side is enough I have a power strip plugged into the other side just to keep all o my junk plugged in (a crap kenwood turntable, a VCR/DVD recorder and a media server) none of which get used.
    The question is: Is the Panamax decent protection, is it lacking in any areas?
    afterburnt wrote: »
    If those things aren't used, why are they plugged in anyway, or even physically there for that matter ?
    It's decent enough for surges and spikes, if that's what your asking.
    Read this....
    http://www.surgex.com/surgetypes.html
    Gives a better description of what your standard power conditioner using MOV's does....or doesn't do.
    I've hence moved away from MOV devices after a lighting strike 100 feet away took out my cable box and a 500 buck Monster Power conditioner. It did it's job protecting everything else, but MOV devices are one and done against lightning strikes. Their toast after that.
  • afterburnt
    tony they are plugged in because of my bad knees, it's hard to get to the floor and harder to get up! I may use that stuff eventually now all I have to do is hit the power strip with my cane lol.
  • afterburnt
    oh and the Panamax site says it is "fuseless and auto restting" so I guess it's not a one shot deal
  • kevhed72
    kevhed72 Posts: 5,153
    You may also want to check out the APC H15 from BH Photo....like 230 shipped and they are a real online retailer, so u are safe.
  • Conradicles
    Conradicles Posts: 6,371
    The APC H15 has served me well for many years. Good bang for the buck power center.
  • kevhed72
    Im pulling the trigger as we speak....don't really need the battery backup, but this seems to be a winner for the price vs. many of the Panamax or Monster offerings
  • Conradicles
    FYI...the APC H15 does not have battery backup.
  • Glen B
    Glen B Posts: 269
    afterburnt wrote: »
    Panamax, APC, Belkin PureAv, and Furman all make good, similar products. Just pick the one with features and number of outlets you need. No consumer surge suppression product, regardless of technology, will protect you from a direct lightning strike. The best protection during lightning storms is to unplug your gear.
    Furman
    furman_pf15i.jpg~original
    Panamax
    panamax_zpsaade7f06.jpg~original
    Belkin PureAv
    belkin_zps16c121f8.jpg~original
    APC
    APC_zpse05a8f0b.jpg~original
