Rotel RMB-1075 5 channel amp
pearsall001
"Feeler only"...still undecided if I want to let it go or not. Great amp, silver face 125x5. If it's a go it'll be for $575.00 including shipping.
I posted this in the Wanted section by mistake.
BUY THIS NOW IF YOU WANT AN AMP TO END ALL AMPS...................
This was the amp I wanted bad bad bad, but my B&K has similar specs........
Great price, great seller, neither really needed as most know that already.
GLWTS!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
How much does that beast weight?
AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
SUB: Rythmik LV12R x2
Source:OPPO UDP-203 -
Is that correct?
May be we should look for a tie braker
It's about 1/2 as heavy as it's big brother the RMB-1095...I should know, I have both of them. After picking both up I can honestly say that my nuts were hurting a heck of a lot more after picking up the RMB-1095. There, the weight problem solved!
Hello Pearsall, I've been referred to you by EndersShadow... Your amp interests me! I'm in Canada, so the shipping would change the price a little I guess! You can send me an email if you want to let it go!
pearsall001 wrote: »It's about 1/2 as heavy as it's big brother the RMB-1095...I should know, I have both of them. After picking both up I can honestly say that my nuts were hurting a heck of a lot more after picking up the RMB-1095. There, the weight problem solved!
Nuts hurt, question answered. GLWS!!
Bam, hows that for helpin a brother out. Long distance sales assistance
Phil, Jesse's a good guy, I vouch for you both, hopefully that means something lol
I bought one off here and FWIR it was around 85-125 to have it shipped + all fees.
Dan: it does mean something, it means that you are a really helpful person and a good guy =D
Willow : thanks for the info, not that bad at all! -
If I do decide to pull the trigger you'll have first dibs. I'm sure the freight to Canada can be a little heavy though.EndersShadow wrote: »Hello Pearsall, I've been referred to you by EndersShadow... Your amp interests me! I'm in Canada, so the shipping would change the price a little I guess! You can send me an email if you want to let it go!
Thanks for the recommendation, he's at the top of the list if I decide to pull the trigger.
Pearsall: thanks! yes, freight is always heavy in Canada, so don't worry, I'm used to it haha!
Hello Pearsall! Just to say thanks for putting me at the top of the list for your awesome deal... I'll have to let someone else take profit of that deal though since I've bought A Rotel on another site! Thanks for your confidence!
Hey Aarghon how far are you from a US city? reason I ask is because I'm in Windsor and I did a lot of my Christmas shopping on Amazon.com instead of .ca because of the way cheaper prices and had it all shipped to mydetroitaddress.com. They emailed me when it arrived and only charge $4.00 per package when you pick up you package.
I know other border cities have similar businesses you could try and use to save a ton on shipping and brokerage fees. good luck I'm going to be looking for a similar deal for my new RtiA9s when I save up enough. -
Hey Scotvl! thanks for the suggestion, but I'm like 500 km from the border... Would be a great solution indeed if I were closer!
