Any Plumber's? Hot Water Heater Question!
So finished watching a movie last night around 11 pm it was over the wife briefly goes into the laundry room says there is water on the floor come to find out the hot water heater is leaking it was late turned of the water going to it shut the pilot off and the gas off to it clean up mess. I a buddy who can get me a new one a little over cost the choices are 40 gallons natural gas the brands to choose from is Ao Smith or Bradford White he told me the 6 year warranty ones are pretty much the same as the 10 year warranty ones the only difference is the model # and the price difference is the cost of the extended warranty.
He can help me install it tomorrow evening or should I say he will install it with me helping which will cost a rib dinner and a few beers. He says Ao Smith is the better choice than the Bradford White the old one was a Menards cheap 30 gallon one but it lasted 21 years, but with the deal for a name brand one I will settle for one of the two mentioned. I ask your opinions plumbers which one Should I get Ao Smith or Bradford White?
I used to sell both brands. We took back less warranty parts on the AO smith than we did Bradford White.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Toss up... I had an AO smith that lasted 17 years and then I sold the house.... BW is very good too.... Take a look at efficiency tho. AO Smith has some that are very efficient and can save you a lot over the long haul... Also have you considered a Tankless HW heater? If you don;t have kids they can be VERY efficient and save LOTS of money over the long haul... Most conventional plumbers will tell you bad things b/c they last forever and they don't put their kids thru college.... Sizing is very important.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I'd probably go with A O Smith, of the 2. I've seen a lot of them that lasted 15+ years.
Draw back of tankless heaters is during power outages. They can freeze up, and not all plumbers can/will work on them. Had a freeze a few years back, and the plumbers where I work we're repairing them for weeks.
Again, not all plumbers can/will repair them -
I've seen a LOT of boards go on Bradfords. With that said, I know virtually nothing on the Smith.
The masses have spoken. SmithWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Neither brand is familiar to me, but I find little difference in gas hot water heaters anyway. Thing is, don't undersize it. 30 gallons wouldn't be nearly enough for me and 40 gallons was on the light side too. I bought a 50 gallon and never looked back.
They are easy as pie to install too.HT SYSTEM-
lsi 9's -
Is your water heater located in your laundry room or above it in the attic? Obviously, those in the attic are more of a pain to r&r. I have a A.O. Smith 40 gallon going on it's 14th year, although I did_ have to replace the thermocouple 2 years ago. Doubt any__ of the new models of water heaters now out there last over 15 years. Just don't make them like they used to.
Yeah, your lucky to get 8 years out of a newer HWH. 10 years and you've won the lottery. A lot also depends on the hardness of your water. Plus it's a good idea to flush them out every 6 months or so, kinda like you do with the radiator on your car. Gets all that rust and corrosion out.HT SYSTEM-
lsi 9's -
Also a good idea to install a tray/pan underneath the new HWH with a drain hose to your sump if possibleMy New Year's resolution is 3840 × 2160
Thanks for all the feedback everyone. They have V bulletin forum's on HVAC discussions, a bunch of guys talking about thier passions which is hot water heaters who would of thought. The 3 best major contractor preferences are Ruud, AO Smith, and Bradford White.
One of the guys who everyone says to ask his opinion says any of those 3 would be good choices with the AO his choice he compared them to cars such as Cadillac, Lincoln, and Lexus so I'm getting the Cadillac which he refers to as the AO Smith. It seems most of you recommend that one also so AO it is. I can't fit a 50 gallon in the space it's going due to the width so have to stick to the 40 gallon.
Thanks again everyone for helping me make up my mind don't think the wife can live more than a day without hot water, she left to go to the daughters to shower I can shower at work, now that she's gone I can crank the tunes. I now can go to the HVAC forum hang out and ask a bunch of newb questions.Home Theater
Go with the AO, you can possibly save some gfuture headache by running an inline to one or two of your high demand items, and a smaller tank style for the house. Constant supply to shower or whatever, no wait for hot water, and you don't have yto pay to operate a big tank for a shower.
I happen to be a plumber and UT(hvac/r tech) in the navy seabees, and been working in or around construction my whole life.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Bought a Whirlpool 40 gallon from Lowes in 2011. It's one of the worst on the market,I've had to warranty nearly every part. Good luck!
So why are you heating hot water?
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Plumbers always tell my to buy all my plumbing stuff at a plumbing supply house. There is a difference, and the extra money is worth it -
The job is done got the AO Smith my buddy is an ex plumber but works at a plumbing supply store got it 10% over cost he bought it at his discount and I get to pay him next payday he saved me about a hundred with him buying it.
He came over after 5:00, I had already disconnected the old one and had it off to the side we carried the old one out, brought the new one in and because it was taller than the old one he had to cut the water lines going in and out added elbows to line them up because it was wider it was installed in an hour and is ready to go. I told him everyone here said to get the AO over the Bradford White and he said told ya. I owe him dinner and a few beers so thanks to all for the suggestions on my heater that makes water hot.Home Theater
That will be my next route for sure when the Whirlpool dies soon. Just bought a Honda 2 stage snowblower and paid a lot more than your average brand snowblower. Got 28 yrs. out of the old MTD, that won't happen with MTD's of today. -
Aside from flushing the system twice a year, you'll want to change out the sacrificial anode every 5-7 years to get the longevity out of it.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Is this relatively easy? I see this post is 5 years old lol but this caught my eye. Our heater is in our utility room and in the adjacent room to my audio room/office.Aside from flushing the system twice a year, you'll want to change out the sacrificial anode every 5-7 years to get the longevity out of it.
You can always check for corrosion on the anode whenever you go to drain the water heater. If it's good, don't worry about it. If there is corrosion, replace it. After 10 years, it may be wise to simply replace the whole unit and bring it up to current code.
Yes it is as long as the heater is fairly new. Once they get years on them and not drained in several there could be enough sediment to block the hose bib at the bottom. Best thing to do is shut incoming water supply off, turn heater itself off and then open all the hot water sides of your faucets, then just open the hose bib at the bottom. If nothing comes out then it is clogged. if it flows freely then let it drain and at the very end open the incoming water supply and that could flush out the rest. If it runs clean then shut bottom hose bib off and let fill until it comes out the faucet the farthest away from the heater. Then relight the heater.
Run a hose from bib to drain unless you have an unfinished basement and a drain near. -
Awesome....this gets added to "the list".....thank you
Good luck getting the anode rod out if it hasn't been removed regularly. When I replaced my last water heater, I attempted to get the anode out of the old one just to have a look see. I twisted the bung out of the tank before I ever got it to break loose.
Just drained mine today. Put in new this time last January and no sediment came out. I know there has to be some in it and I even flushed with more water from the shut off valve. I remember on my old one you had to stick a screwdriver into the bib to loosen the sediment to get water to come out of it. The old one was a Whirlpool and had a digital gas valve on it. I probably had warrantied 4 valves for it. This time I bought the cheapest Menard's with a mechanical valve.
Gotta love a thread from 2015 being brought back from the dead by an apparent spam bot lol......."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I was getting about 3-5 years out of my electric hot water heaters and I would flush them several times in the winter months. On a whim I stopped flushing several years ago and I'm at 10 years on my current one without ever having flushed it. A bit of sediment isn't a bad thing in my case as I was getting really good at swapping hot water heaters.
10 years is pretty good by todays standards. My previous Whirlpool gas heater only last ed 8 years with annual flushes. A plumber I know says there really isn't good quality heaters anymore. He said just buy the cheapest and cross your fingers. They've gone up about a 100 bucks in price since I got the Whirlpool back in 2012.
At least you caught it before it got bad. I replaced a 40 year old Ruud water heater last year. My plumber friend installed a 40 gallon State brand water heater, this is one of many brands made by A.O. Smith. Very nice heater. Plumber said don't expect it to last as long as the old Ruud. All are pretty similar anymore. Like tonyb said if you get 8-10 years... you're golden. EDIT: Yikes, I need to look at dates on these threads!
The best money I have spent recently was installing a mixing valve on my water heater. This allowed me to crank the tank to 140 and at a later state mix in cold water to make it 120. It makes it seem like unlimited hot water, haven't ran out of hot water since. Also don't have to play with the faucet for a shower as 120 is the perfect temp! Haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Been thinking about a recirculating pump. The water heater and master bathroom are on opposite sides of the house, and it takes minutes for the hot water to come through.
Anyone have experience with them?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Recirculating pumps are awesome for long runs but they are best if you insulate the hot line going to the far spigot. There are basically two ways to do it. One is have a pump on your HWH and have sensor valves attached to the farthest sink.
https://www.homedepot.com/p/Watts-Hot-Water-Recirculating-System-with-Built-In-Timer-0955800/100426993
https://www.homedepot.com/p/Watts-Hot-Water-Recirculating-System-Sensor-Valve-Kit-Sensor-Valve-Kit/100493462
This way if you have multiple bathrooms a long ways from the HWH you can put a sensor valve in each room. The other is to have one under the kitchen sink (or any sink that has an outlet next to it) that is a pump and sensor all in one like this.
https://www.ebay.com/itm/AquaMotion-One-AMH3K-R-Hot-Water-Recirculation-Kit/254007743514?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=40719&meid=ad1f0fd56225489cbe433764b6533512&pid=100675&rk=4&rkt=15&mehot=none&sd=223714195741&itm=254007743514&pmt=1&noa=1&pg=2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci:96c6817a-3a8e-11ea-b277-74dbd1802106|parentrq:bcbc7fa016f0aa48c3e265d0fffaad04|iid:1
With the ladder the pump only runs when the temp drops and it's recirculating and you can program it to only run at certain times. The previous version is probably best for large homes with multiple bathrooms with long runs.Gustard X26 Pro DAC
