how to install mm6 to S2000 (2004model)
Systems
Hi.
I had jetta GLX 2001 with mm6.
But i sold it & bought new S2000 last week.
I still want to install mm6 on this car but i don't know it's gonna fit or not. Also I'd like to know how to install it without any scratch.
Testing
Testing
Testing
Testing
Testing
i seriously doubt anyone here knows the answer to that...
best bet is go to an installer and have them do it or try it yourself
One can always cross-reference the MM6 via polk's support or using the crutchfield thingy (CruthField)
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
Chances are both will say they wont fit however that usually means it wont fit "easy".
Its a good bet youll need to do a little "finessing" in order to get them into place.
If youre worried about messing up your new ride then Cody's advice is best, go to a competent installer and let him take a look at it.polkaudio sound quality competitor since 2005
