SDA-1B which wire colors are positive/negative
I am looking for clarification on which wires are positive and which are negative on my Sda-1b's. The schematics do not specify. Thanks, Brad
  • PolkieMan
    PolkieMan Posts: 2,446
  • PolkieMan
    edited January 2015
    White should always be negative and if you see a green one (which you should not) it would be too.
