Polk Audio SDA SRS 1.2TL Ultimate Build Part 3
VR3
This one is for one of our own!
Tweeter Network -
Clarity Cap MR
Duelund Resistors
Jantzen Inductors
SDA/Stereo Network -
Clarity Cap MR
Jantzen Perfect Lay
Jantzen C Coil SDA Inductor
Other Features -
Shelf Build with "invisible" SDA Inductor mount
All Supra Rondo wiring, PTP and internal, "pretty wiring", blue tech flex in the areas you cant see so it looks good in case you do see it
9 Awg SDA cables, NL4 on one end, banana plugs on the other, black tech flex
Lexan substrate
WBT Binding Post, Aluminum terminal plates
"Mirror imaged" build
Tweeter Network -
Clarity Cap MR
Duelund Resistors
Jantzen Inductors
Clarity Cap MR
Jantzen Perfect Lay
Other Features -
Lexan substrate
Wow, sexy as hell...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Looking beautiful, Trey!
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
PTP
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
PurdyPolitical Correctness'.........defined
President of Club Polk -
Absolutely stunning Trey!
I am always amazed at the size of the MR Clarity's. That 27uF cap is F-ing huge!
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Thanks guys!
I appreciate the kind words!
The 400V MR is pretty big but the 620V is much larger. IE - the 12uf in the 620V is the same size as the 27UF in the 400V. They are pure monsters!
Here is the 620V 12uf
First of its kind, not sure of where we could take it. MR/ESA/Mundorf Mox/Jantzen
I figured while I was posting pictures - it would be neat to see all the iterations of this build from the past...
Full out build, MR/Jantzen/Duelund
First SDA SRS
Full Out, Suspended shelf design with faceplate SDA SRS, MR/Jantzen/Duelund
Amazing pictures and build quality Trey!
I think I asked this before, but why are the customers not using teh Duelund Cast resistors for the "all out build"? If you are gonna spend that kind of money on the MR Clarity's, why not spend slightly more on the Cast resistors?
Thanks man!
The best answer I can give you is that each build is a transition to the next. The first time I built this, the concept did not even exist - what can you even fit on this thing, what can we do with it. The first build was a "cost no object" build but it only came to $3,500 or so. To be honest that build started as a GIMPOD modification and then as we waited on the inductors, the shelf concept was born and the entire build was changed after the plans were made.
From there after people saw the first build it was a matter of, I am willing to spend X, what can we do with X. So then you start to see more and more happening.
The latest build, the SDA SRS went way over the top in the design and installation phase of the build. Each crossover took over 6.5 hours to install in the speaker with the suspended build. But I absolutely love how they came out.
So to answer your question, I do not have a great answer, this is kind of like the "custom shop" of speakers. The only limitation is what we can imagine at the beginning. So on the next one I will throw it out and see what happens. I have a set of 1.2TL from Australia here that is in the pipeline after this current build and we are still in the consultation phase.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I wanted to update this, I had lost my Camera when I was finalizing them- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Superb. Good job VR3.
Thank you!
Looks awesome as always Trey!!
The time it takes to just do the wiring alone is incredible let alone the crossovers.
Trey, I'm just getting to the internal wiring now with the stuff I purchased from you over a year ago, just got away from the hobby for awhile I guess.
I really thought doing the wiring harnesses wouldn't take that long, boy was I wrong..
For those of you that have had Trey do the work, it was money well spent. It's fun to do it yourself, if you have the time...
Again, they look fantastic Trey!!! -
Thanks Larry!
The internal wiring for me is easiest by laying everything out on the floor as it is in the speaker. Precut all of the lengths, then zip tie it all together then terminate but it does take a good 3-4-5 hours to do all of the internal wiring which is alot more than people would think.
Even making a cable, putting the tech flex on, terminating the ends, it takes longer than you would think...
The set up you made looks great, everything looks spectacular.
I wish I had access to a CNC machine - I have contemplated investing in a 3D printer to print out my substrates with all of the holes predrilled and everything but I cant make up my mind..
Thanks again - by the way someone emailed me about your rings and I directed them to your email but they said they didnt hear a response?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Maybe in my junk email, I will look...
A 3D printer would be sweet....
