XPA-100 Monoblock for center or is this just stupid
I have got an XPA-200 on the fronts. Is it a good idea to add a XPA-100 Monoblock just for the center?
  • afterburnt
    afterburnt Posts: 7,892
    That is if I can even find an XPA-100 Monoblock
  • polrbehr
    polrbehr Posts: 2,842
    Stupid? No, but I would say it's a bit of overkill to add a separate amp for your center.
    That Yammy is 110 x 7, and I believe you're using the preouts for the fronts, so that means it's only being asked to drive the center and four surrounds. That AVR should handle all that and more easily.
  • afterburnt
    How about an XPA-3 on the fronts and center and move the XPA-200 to the sides? Looks like I have the space and the funds. The problem is that some of my sources need the dial turned up in order to equal the output of other sources.
  • polrbehr
    Not sure I understand what you mean there. Equal the output of other sources?
    Adding an amp will give you more headroom and will take some strain off the power supply in the Yamaha (if you want to crank it up to concert levels) , but judging by what's in your sig you should be OK with what you have.
  • afterburnt
    edited January 2015
    Example: A blue ray disc sounds fine at -20 but the same movie on Netflix needs to be closer to -5 or more to sound the same. There is also variation from one streaming source to another, I have a smart tv and two smart blue rays(3 counting the ps3) hooked up and they all output at different levels. I don't use the built in streaming from the TV because that would probably require turning the volume up into the positive range although the TV streaming would be the most convenient to use.
  • polrbehr
    edited January 2015
    OK, that's what I thought you meant but wasn't sure. If there is a way to control input levels in your Yamaha, you can try to equalize your sources that way, though I don't see the big issue there.
    I have several sources as well (CATV box, PS3, Oppo 103) and a Denon 3312 connecting them all, and while there are differences in sound output between sources, I figured that was just the way things were. I never gave it a thought to try to boost input levels to get them to sound similar at the same volume level, as it seems like they are not really that far apart. And keep In mind, there are going to be some differences between media types even in the same source/player; I have a few Blurays that were obviously engineered on another planet!
    And per your original post, I don't think adding an amp would address that anyway, the amp is only sending out the signal it receives.
  • mrloren
    mrloren Posts: 2,474
    add the amp if you have the funds. i would just add an XPA-3 or XPA-7.
    i know what you are saying when audio sources require louder volume to sound the same. I hate it when my kid watch Netflix and don't turn down the receiver to -20. I come to watch a BD and the receiver is at -10. The start to Edge of Tomorrow knocked a picture down...
  • afterburnt
    Exactly mrloren!
    polrbehr if I can find out how to raise the source output level that would solve the problem. I just don't want to blow something up trying to hear Netflix at the proper level. This BB has got me scared to run close to zero lol. I also sort of want a big fat amp sitting there instead of this puny looking XPA-200 lol.
  • afterburnt
    ZLTFUL wrote: »
    Why not use the audio return channel from the TV to "match" the volume of all of your sources?
    Any idea how to do that?
  • afterburnt
    ZLTFUL that is how I have it setup but I don't see how to run anything other that the TV output through the ARC?
  • afterburnt
    ZLTFUL are you telling me to hook everything up to the TV instead of the AVR?
    tonyb Posts: 33,069
    afterburnt wrote: »
    No, I wouldn't do that.
  • gp4jesus
    gp4jesus Posts: 2,016
    ZLTFUL wrote: »
    ...use the audio return channel from the TV to "match" the volume of all of your sources?
    I like the idea. Do HDMI ARCs return what it receives? (e.g. DD) My TV's Optical Out (OO) outputs DPL2 while my cable box &/or BD player output DD.
    Apologies still running last century's signal tech. Eyeing HDMI 1.3+ prepro for tax refund (Outlaw 975?)
    *all connected w/Premiere ICs
  • afterburnt
    Thanks for trying to help. My head just exploded again.
  • afterburnt
    Gp4jesus as far as I can see any audio signal that goes into the TV will be sent back to the AVR via the HDMI ARC. As far as audio signals going into the AVR then out to the TV and then back again to the AVR to be output to the speakers. I have yet to find the setting that will do that. All that I have is the TV audio going back through the ARC to the AVR.
  • polrbehr
    afterburnt wrote: »
    Exactly mrloren!
    Check the link ZLTFUL included, it seems right in line with what you're trying to do.
    If you want to add an amp to your system, go for it. I was not trying to discourage anyone from doing so, the increase in power (headroom) would be beneficial. Rather, I was trying to spare you what would likely be disappointment when it did not help you with your original issue.
    I stream Netflix wirelessly from a PS3 > Denon 3312 via HDMI, and can say that at -15 I would be hard pressed to hear anyone else in the house at that level. I have only listened to my system once at 0 (the intro to 2112 from the R30 DVD) for about 30 seconds before it got annoying. Not harsh or clipped, just LOUD lol. And that is without any external amps in my system.
  • afterburnt
    polrbehr as I said above I have that set on the AVR the TV does sends it's audio out through the ARC to the AVR however I can not figure out how to get audio from any of the peripherals connected to the AVR into and back out of the TV to the AVR like ZLTFUL has suggested. That is if I am reading him correctly. Thanks for the help but I think I will just take a hooligan tool to my AV equipment and curl up with a good book, naked in the fetal position under the coffee table wet myself whimper and tremble for a while. %^(
  • afterburnt
    Instead of having the above stated meltdown I've ordered an XPA-3. I know that it wont resolve the issue but I feel better now lol.
  • mrloren
    what are you going to do with your XPA-200?
  • mrloren
    Trade you a CSi5 for it
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2015
    Good luck with the Emotiva.
  • Polkie2009
    afterburnt wrote: »
    Have you tried the Emotiva forum for any help?
  • afterburnt
    mrloren I am going to hook it up to the surrounds for the time being I will eventually use it for a second zone. Thanks for the offer but i am going to keep it.
    Polkie2009 no I haven't but I will try it.
  • trj
    trj Posts: 320
    mrloren wrote: »
    Are planning to sell the CSi5? I thought you were going to keep it after reading your other thread. I would be interested if the price is right and you are nearby. Shoot me a PM.
    Sorry, OP didn't mean to derail the thread.
    I have similar problem too. Netflix, youtube and radio are fine but the volume from OTA signals for TV (fed through co-ax) is low. I have to bring the receiver rx-v667 to -20db, while all other sources sound pretty good at -30db. Unfortunately, my cheapo TV doesnt have ARC to test.
    I have set my AVR to -30db at start up so I don't go boom when I turn on the radio, BD or netflix. I have Xsight touch remote, so I can get to all the activities with a single button. Helps my volume issue as I usually turn off everything(one button) before going to bed, thats usually TV+receiver at -20db. And I turn ON the receiver or receiver change input to HDMI 1+ netflix/pandora (BD player) or just receiver +change input to radio (one button) in the morning. I would hate the radio to start at -20db at the morning, so setting the default at -30db has worked well for me.
    Sorry, its not a solution but a work around.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • afterburnt
    trj that will solve the problem of blasting myself thanks
  • trj
    trj Posts: 320
    Yah, I would highly recommend Xsight touch universal remote and read up on RMIR to program it. I ordered one from ebay for about $35. Touch screen and can control 18 devices. Wife is super happy that she doesnt have to rumble through the cluster of remotes on the coffee table and I don't have to teach her every time.
  • kevhed72
    kevhed72 Posts: 5,139
    trj wrote: »
    mrloren wrote: »
    Would a signal booster help with your OTA signal for TV....it does wonders for my OTA for radio. Yes, I still use a radio tuner
  • kevhed72
    afterburnt wrote: »
    I would amp my center and fronts for sure. Maybe even 3 mono blocs....
  • afterburnt
    kevhed72 my only souces are streaming, no TV I got rid of my directv and I live a canyon and get no FM signal. I am Waiting for my XPA-3 that will be on the fronts and center The XPA-200 IS going to the surrounds and I want an XPA-2 but I have no room for it.
  • trj
    trj Posts: 320
    kevhed72 wrote: »
    What kind of signal booster? For the antennae or the coax cable that I am running from TV to receiver.
    I use the radio tuner on my receiver a lot too. In fact, the sound from the radio stations are the clearest and the loudest at the same volume.
    I am thinking to try Coax to optical powered converter from TV to receiver and see if it makes any difference. But, then I read that optical cable doesnt transfer 5.1 signals. :(
