Sandworms, Please check your PM
Thank you....
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Are you after his Epik Valor???? :)
  • Erik Tracy
    Hah! Knew it!
    He was after mine for a bit - surprised he was putting his up, but he found a good alternate setup - which left me sorely tempted to turn the tables and get his so I could have two Valors!
  • Polkie2009
    Polkie2009 Posts: 3,834
    That would__ be a killer setup, running two Valors. Could you imagine running two Conquests? :)
  • kevhed72
    kevhed72 Posts: 5,130
    Erik Tracy wrote: »
    Hah! Knew it!
    Are you using yours for ht, music, or both?
  • Erik Tracy
    Both.
    Unique connection via AVR and Int amp w/ bypass.
    I can have my cake (avr w/ bass management) and eat it (no AVR, just 2-channel goodness), too.
  • kevhed72
    No regrets on the music side with only one sub....
  • Erik Tracy
    edited January 2015
    Regrets? No.
    I just went scare the neighbors loud with some Porcupine Tree - shook the house good.
    The Epik Valor is that good.
    Temptations to go to two???
    Oohhh yes!
  • kevhed72
    Well, I should have it sometime next week. I plan on adjusting my audio room a bit to try to place the sub dead center between the 703s....have to go take some measurements. I really wanted a pair of SVS sealed but at this time the Epik was the more wallet friendly.
  • Erik Tracy
    I think you will really enjoy the Valor - a nice sealed design for musical results!
  • sandworms
    sandworms Posts: 1,043
    Guess I'll join the conversation, sorry haven't checked in much lately, not fond of the new format. Sub is on its way Kevin, thank you so much and enjoy. I hoped to get Eriks but he wouldn't let me pry it from his warm live fingers! I wanted the dual sealed epiks but settled for dual hsu's, maybe overkill but it is smooth for movies
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • sandworms
    Kev, check your agon box
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
