Sandworms, Please check your PM
kevhed72
Are you after his Epik Valor????
Yes...
Hah! Knew it!
He was after mine for a bit - surprised he was putting his up, but he found a good alternate setup - which left me sorely tempted to turn the tables and get his so I could have two Valors!
That would__ be a killer setup, running two Valors. Could you imagine running two Conquests?
Are you using yours for ht, music, or both?Erik Tracy wrote: »Hah! Knew it!
Both.
Unique connection via AVR and Int amp w/ bypass.
I can have my cake (avr w/ bass management) and eat it (no AVR, just 2-channel goodness), too.
No regrets on the music side with only one sub....
Regrets? No.
I just went scare the neighbors loud with some Porcupine Tree - shook the house good.
The Epik Valor is that good.
Temptations to go to two???
Oohhh yes!
Well, I should have it sometime next week. I plan on adjusting my audio room a bit to try to place the sub dead center between the 703s....have to go take some measurements. I really wanted a pair of SVS sealed but at this time the Epik was the more wallet friendly.
I think you will really enjoy the Valor - a nice sealed design for musical results!
Guess I'll join the conversation, sorry haven't checked in much lately, not fond of the new format. Sub is on its way Kevin, thank you so much and enjoy. I hoped to get Eriks but he wouldn't let me pry it from his warm live fingers! I wanted the dual sealed epiks but settled for dual hsu's, maybe overkill but it is smooth for moviesSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Kev, check your agon boxSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
