WIRING SPEAKERS
MY SPEAKERS ARE MONITOR T 75 , AMP IS YAMAHA AS-700.
QUESTIONS:-WILL BIWIRING GET ME BETTER SOUND?
SHOULD I GET A PURE AMP AND USE YAMAHA AS A PREAMP?
- DO I NEED A DAC TO GET BETTER SOUND WITH ITUNE SONGS?
THANKS.
Best Answer
Answers
  • beru
    beru Posts: 20
    NEW TO THE HIFI "KINGDOM"!
    beru wrote: »
    THANKS.
    Biwiring....not necessarily, but....you should swap out those cheap metal jumpers on the speakers for some good quality speaker wire.
    Your Yamaha is fine for those speakers, but any speaker will benefit from additional current fed them. So the answer is, if you can afford it, look for a used Parasound or B&k amp, around 400 bucks.
    ITUNES....if that's your source for music, yes....a dac would help out greatly.
  • beru
    beru Posts: 20
    AM USING 14 GAUGE COPPER OXYGEN FREE WIRING FOR SPEAKERS, PLUS GOLD COATED BANANA PLUGS. ANY RECOMMENDATION ON A dac?
    edited January 2015
    Have a budget in mind ?
    Speaker wire, you can do better.
  • beru
    beru Posts: 20
    better speaker wire? elaborate please?
    dac: maybe 300 $
    Cambridge dac magic used is certainly in your ball park and probably the best bang for your buck in that price range.
    Speaker wire is simply a matter of tastes, like an ice cream shop there's just too many flavors to name them all. Think of standard 14 ga as vanilla in a shop of 50 flavors. On a budget, buy cables used as they normally run half the cost of new. Kimber cable, PNF, Analysis plus, MIT, Audioquest, are just some of the more popular brands some use. Douglas connections is a company run by one of our members and offers a good well built cable for not a lot of coin too. Signal cable is another.
    Like everything in audio, sometimes you have to kiss a few frogs to find your prince.
  • beru
    beru Posts: 20
    re:swap metal jumpers with cable? please explain?thanks.
  • mrloren
    mrloren Posts: 2,474
    Yes a DAC will help itunes and MP3 Reason I still have over 1000 CD's is
  • voltz
    voltz Posts: 5,384
  • footwedge
    footwedge Posts: 475
    beru wrote: »
    Why are the speaker cables attached to the upper binding post? I have LSI 7s and cable is on lower post. Is this wrong?
  • ken brydson
    ken brydson Posts: 9,060
    footwedge wrote: »
    beru wrote: »
    You can connect to either top or bottom whether you are using the plates or jumpers.
  • footwedge
    edited January 2015
    [/quote]
    Why are the speaker cables attached to the upper binding post? I have LSI 7s and cable is on lower post. Is this wrong?[/quote]
    [/quote]
    [/quote]
    Why top over bottom and opposite hand?
    opposite hand ?
    Doesn't really matter which posts , top or bottom you connect to first as long as those jumpers are there.
  • footwedge
    tonyb wrote: »
    opposite hand ?
    vice versa
  • footwedge
    Sorry for the double quote was using iphone.
